cold air intake
Old 25 Jan 2012, 08:11 pm
Default cold air intake
if you have enough room can i run the air intake down to where the fog lamp should be because i do not have a fog lamp so i found some connecting pieces and i do believe it will fit would that be a upgrade
Old 25 Jan 2012, 09:01 pm
Default Re: cold air intake
It would be a modification to your intake, not sure you would call it an "upgrade". I did it at one time with plastic pool hose in the hole next to my fog lamps. Didn't like the way it looked.
Old 25 Jan 2012, 09:04 pm
i have also looked around at other post and i have seen alot of airbox mods what is the "air box mod"
Old 25 Jan 2012, 09:23 pm
Read here:
How to: Air filter box modification
Tags
air, cia, intake
Cold air intake Wfl3rd Tech & Performance Forum 8 01 Sep 2010 09:44 pm
cold air intake ptguy69 Tech & Performance Forum 1 11 Jun 2010 06:10 pm
Bst Value Cold Air Intake? monk General Turbo Discussions 31 02 Jul 2007 12:21 pm
Cold Air Intake Mr.Barton Turbo Performance 20 08 Jan 2006 09:35 pm
BTG Cold Air Intake Mr.Blonde General Turbo Discussions 7 05 Jan 2004 02:49 pm
