Squeak
Old 26 Jan 2012, 09:41 pm
Default Squeak
I have noticed a small squeak at times with my car. It sounds like a belt but it is not constant. When this happens it seems my car runs a little bit on the hot side. I was wondering if anyone knew what it could be?
Old 26 Jan 2012, 09:50 pm
Default Re: Squeak
Wow, not a lot to go on. Have you looked for mouse droppings?
Has the actual temperature gauge go up past the middle when it's squeaking?
Old 27 Jan 2012, 09:59 am
davea300's Avatar
Default Re: Squeak
Any idea whereabouts its coming from?
2005 2.4 PT CRUISER (UK SPEC)
Short ram intake, chrome grill, chrome belt line, drilled/slotted discs, few flames, engine dress up, chrome bits and pieces.
67,000 miles
Old 28 Jan 2012, 10:51 pm
Default Re: Squeak
It sounds like it is coming from the front of the engine. It sounds like a whistle or a squeak. I thought it was a belt but I can't tell if that is actually it or not.
Old 29 Jan 2012, 06:06 am
davea300's Avatar
Default Re: Squeak
Its perhaps the alternator belt needing adjusted. It can cause a squeak if its slack. Mine is the same (and still is to be honest but it's so slight now I can hardly hear it). The adjustment is done via bolts on the alternator/bracket itself. If it is that you have get underneath the car to see it, take the passenger side wheel off and remove the splash shield. I'm sure there's a more detailed post on here with a link to a video if you want to have a search.
There are also various posts here on 'belt noise' as it may not be that, when mine was 'chirping' I didn't notice any temp increase as you have mentioned so it may be a different problem.
67,000 miles
Pulley/Belt squeak StealthyK Tech & Performance Forum 3 15 Jul 2011 09:48 pm
Squeak From Rear of Car funksoulkitty Tech & Performance Forum 2 12 Jun 2007 04:38 pm
weird squeak ??? legion General PT Cruiser Discussions 4 07 May 2005 01:42 pm
Brakes Squeak Konkeler Tech & Performance Forum 5 01 Jun 2004 12:40 am
High Pitched Squeak SFsGT03 Turbo Wheels/Suspension/Handling 2 08 Nov 2003 06:37 pm
