rear wiper issues
Old 26 Jan 2012, 11:03 pm
Default rear wiper issues
Ok I give up I've looked in the book and done tons of searches and am evidently research inept. Can someone tell me which fuse controls the rear wiper on a 2006 pt please?
Thanks
FARM
Old 26 Jan 2012, 11:37 pm
Default Re: rear wiper issues
Unlike the 01-05 models where they have the interior fuse box and the PDC (Power Distribution Center) with fuses and relays for just about everything on the PT, the 06+ models changed everything and now there's just one box under the hood called the IPM (Integrated Power Module). A lot less fuses and relays which means things are integrated together but not listed in any of the easy to get manuals. I'm sure there is a fuse for the rear wiper but it's just not listed in the owners manual or under the IPM box lid.
Old 27 Jan 2012, 07:19 pm
Ok all the fuses are good or look to be so any easy quick checks to look for issue?
Old 27 Jan 2012, 07:29 pm
Nothing quick and easy. All the panels on the rear door/hatch come off by just pulling. Try to take as many off to get to the motor for the rear wiper and see if it's getting 12 volts. If it is, it might be a burnt out wiper motor.
Old 27 Jan 2012, 07:46 pm
Its not uncommon for these to go bad. Cover removes easely. Check voltage as Instructed. Most likely needs a new one.
Old 28 Jan 2012, 10:00 am
ukbeachbum's Avatar
Also check the wiring loom inside the rubber sleeve that runs between the hatch and the car. I had two wires that had simply snapped in two. Reconnected them and my dead rear wiper motor and rear defroster came back to life.
2000 PT Cruiser Ltd Edition, blacker than black, Auto, 2.0L
Fixed: Cloudy headlights, Rear Defogger, Rear Wiper Motor, Multifunction Switch, Clunking noise up front......
BUT-Odometer not recording every mile-Turn signal warning chime always chimes-Temperature light always on...
...Still love the damn thing
Old 28 Jan 2012, 01:21 pm
That's exactly why you need to check for voltage at the plug! He isn't a bum after all. lol
Sorry I just had to go there.
Old 28 Jan 2012, 04:16 pm
UptownSport's Avatar
Mine's motor failed due to water seeping in the shaft- The '01's were the same as C-vans of my year, so I got one for next to insignificance $.
I had problems checking voltage for some odd reason, and erroneously bought a new switch from Chrysler
Old 28 Jan 2012, 05:32 pm
I had the same problem with water down the shaft. I used the parts from a donner that wouldn't bolt up. It was there what can I say. Free is free.
Rear Wiper issues PTCMIAH62 General PT Cruiser Discussions 16 23 Apr 2011 11:04 am
Rear Wiper issues dearler General PT Cruiser Discussions 4 13 Apr 2011 07:47 am
Rear wiper Balljoint General PT Cruiser Discussions 6 01 Jul 2010 09:06 am
rear wiper DiesAl General PT Cruiser Discussions 1 23 Dec 2009 11:22 am
Rear Wiper MOD Gary04GT Exterior Accessories Forum 4 23 Feb 2004 02:11 am
