P0420 help
Old 27 Jan 2012, 03:51 pm
Default P0420 help
P0420 Catalyst System Low Efficiency
Having this error message, any help with what it means and what i need to do is appreciated.
Old 27 Jan 2012, 04:03 pm
UptownSport's Avatar
Default Re: P0420 help
Not an emissions expert, but downstream oxygen sensors only job is to check catalyst's efficiency.
Seems in this case it's done so, (Whether accurately or not is debatable) and is reporting the 'cat' is no longer efficient.
You could simply ignore it, and assume sensor is the problem.
Old 27 Jan 2012, 06:48 pm
I would Start with changing the o2 sensor with a OEM from Chrysler.
P0420 WolfmanG Tech & Performance Forum 9 20 Sep 2012 01:58 pm
P0420--Cat efficiency low bank 1? ZY100 Tech & Performance Forum 12 11 Aug 2012 08:17 pm
P0340 solved now have P0420 garciaag Tech & Performance Forum 7 18 May 2010 03:15 pm
