no code no start
Old 29 Jan 2012, 07:24 pm
Default no code no start
The engine was running hot. I very carefully replaced to timing belt, water pump etc. I found a bad freeze plug which I replaced. would not start. Did a compression test, found low compression on three cylinders. I replaced the head gasket and rechecked the timing belt. Everything looks good, the engine almost starts but won't. I have spark and fuel because it fires sometimes. Where do I look next? There are no codes. It acts like it wants to start but won't. The timing marks all line up. Help!!!
Old 01 Feb 2012, 10:39 am
Default Re: no code no start
What is the likelihood of the CAT being clogged?
Old 01 Feb 2012, 05:28 pm
Not very likely, but nothings impossible. You'd be the first one to report it. You might have to have it scanned to see what the problem is.
Old 01 Feb 2012, 09:43 pm
I would check compression again. If ran hot enough could have collapsed rings and dose not have enough compression to start. If that checks out OK. Go over every thing check all hoses (vac) & wiring connectors etc. Make sure there are no intake leaks also. Let us know what you come up with.
Old 05 Feb 2012, 03:31 pm
I got a snap-on scan tool and no codes present. It is showing both crank and cam sensor input. If I give it about 3/4 throttle it acts like it wants to start but it wont quite start. This tells me that I have spark, fuel and compression, or am I missing something?
Old 05 Feb 2012, 04:57 pm
Maybe your not getting full spark (enough voltage). Try jumping it with a good battery to strengthen your voltage.
Old 05 Feb 2012, 05:04 pm
Never said if you confirmed compression after repairs.
Old 12 Feb 2012, 03:54 pm
Well I bit the bullet and did as busted suggested and re ran the compression test. I got 90, 30, 30, 90. Not good at all. Poop, darn, fudge!!!! So I am going to do it all over again, but this time I will get the head resurfaced. By the way when I put oil in the cylinders, the pressure only came up a few lbs.
Old 12 Feb 2012, 05:02 pm
Sucks to be right sometimes. The 90lbs a little low too. 100-110lbs especially after the oil would sound better to me. You might give a shout out to uptownsport and run the numbers by him. Judging by some of his posts he seems to have a lot of motor rebuilding expertise. I'm still new around here, there are probably others also.
Old 07 Mar 2012, 01:37 pm
The head turned out to be 10 thousands out and all of the valves were leaking. Had the head shaved and a valve job done and I am going to instal a head shim with the new head gasket. Hope it starts OK.
Engine Won't Start -- Code P0129 nimblemotors Tech & Performance Forum 2 29 Apr 2016 09:45 pm
P0340 & P1391 code // cold start & occassionally stalls apalomo01 Tech & Performance Forum 13 28 Jul 2012 08:00 pm
P0700 code & car won't start HELP! hectormc29 Tech & Performance Forum 2 05 Feb 2011 07:03 pm
code 340 no start with spark rstanch Tech & Performance Forum 12 24 Nov 2010 10:12 am
Code P0340 car shut down and won't start up... bigjoe1651 Tech & Performance Forum 5 10 May 2010 07:55 am
