Dash lights and tail lights out
Old 31 Jan 2012, 06:06 pm
ab1 ab1 is offline
Question **ISSUE RESOLVED**Dash lights and tail lights out
2001 PT Cruiser, The Battery went bad so I replaced it. After doing so, the Dash lights and tail lights would not work. I have checked both fuse blocks and all fuses are OK. I also read on another site it could be the multi switch. Where is the multi-switch located? Thanks for any help
***UPDATE***
After I removed the multifunction switch I noticed the ground wire on the wiring harness was disconnected. I plugged it in and everything is working correctly.
Old 31 Jan 2012, 06:44 pm
Default Re: Dash lights and tail lights out
The stem on your steering column. The one that controls your lights. If that is you problem.
Old 01 Feb 2012, 04:34 pm
ab1 ab1 is offline
Problem resolved!! Loose Ground wire!
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
tail/dash lights out chataries Tech & Performance Forum 13 27 Jan 2013 01:38 pm
Problems with Tail & Dash lights calabris General PT Cruiser Discussions 1 26 Jan 2011 12:05 pm
Smoked tail lights and reverse lights! chris15 Exterior Accessories Forum 15 01 Jun 2010 05:53 pm
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
