Replacing a Radiator Fan Relay in a 2008 PT Cruiser.
Old 01 Feb 2012, 05:39 am
Default Replacing a Radiator Fan Relay in a 2008 PT Cruiser.
Hey all, I am new here and at my WIT'S END with my Cruiser and I am trying to figure it out!
I am having some issues with stuttering and air conditioner cutting out intermittenly and from some online searching deduced it could be caused by the Radiator Relay, so I decided to replace it.
Went to Autozone, bought it, and went home to replace it. Opened the fusebox, where the Autozone guy said it was, and there are NO relays in that box.
So I poked around, and I even found some near the radiator fan, but I cannot figure out how to open them...cheap burberry clothing
Old 01 Feb 2012, 06:25 am
Default Re: Replacing a Radiator Fan Relay in a 2008 PT Cruiser.
Autozone was just a few years off in their help. The 01-05 cruisers had the relays in the fuse box located in the engine compartment but in 2006 all that changed. You did fine the right relays on the upper corner of the fan housing but I don't understand your question. Why would you want to "open" the old relays? You just replace them with new. I don't think they are made to "open".
Low Speed Radiator Fan Relay gminfla Tech & Performance Forum 6 27 Jun 2013 10:23 pm
Replacing a Radiator Fan Relay in a 2008 PT Cruiser. RMThompson Tech & Performance Forum 5 11 Aug 2012 09:39 pm
Removing - Replacing Radiator Fan 2006 PT Cruiser Base Model CashReject Tech & Performance Forum 4 31 Oct 2011 12:57 pm
2008 PT Cruiser Touring - radiator fan always on frade Tech & Performance Forum 10 15 Sep 2010 06:56 am
Radiator fan relay on 03 turbo MINIHEMI46 General Turbo Discussions 2 03 Jul 2007 06:02 pm
