pt timming
Old 03 Feb 2012, 08:09 pm
Unhappy pt timming
when the old timming belt was on the car it was 1half tooth off would that cause the compresion to read at zero? or is it bent valves?thanx 4 looking
Last edited by cooltooldual; 03 Feb 2012 at 08:13 pm. Reason: trying to fix my sister inlaws pt
Old 04 Feb 2012, 12:09 am
UptownSport's Avatar
Default Re: pt timming
If it has zero PSI compression, either your gauge is broken or the cams are a heck of a lot more than 1/2 tooth off.
Old 04 Feb 2012, 03:54 pm
fabreezai's Avatar
2X What Uptown said.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 05 Feb 2012, 01:21 pm
What about the valves could they be bent?:
Old 05 Feb 2012, 02:02 pm
SCBluePT's Avatar
If the valves are bent you still shouldnt get a compression reading that low.
Old 05 Feb 2012, 02:36 pm
Unless it's a Euro 2.0 it'd be very difficult to bend two valves letalone eight that'd be need for zero on all cylinders.
Taking head off isn't that hard once you're into the belt, so if you're itching to
remove it ...
Old 05 Feb 2012, 03:13 pm
Put it in time with the crank using the old belt. Make sure everything is in time then check compression again. If both cams are turning you will probably find you have a compression reading above 0.
Old 05 Feb 2012, 04:44 pm
Here's an EZ how-to cam alignment pic, courtesy of the booger man:
Just
stick something, anything in the two holes; they need to point straight up!
Timming Belt Change Help-Getting to tensioner Candace Tech & Performance Forum 3 26 Jan 2010 12:32 am
Timming marks 01 Cruiser 2.4 Candace Tech & Performance Forum 1 08 Mar 2009 03:40 pm
