installing the TPS
Old 08 Feb 2012, 07:26 pm
Default installing the TPS
took that part of the intake off to clean the IAC and figured I would take the TPS out too just to make sure it was clean and working. When I went to put it back in it has to be installed with tension on it or with a few millimeter gap before it would engage. anyone know which way to install it?
Old 08 Feb 2012, 09:00 pm
sanatanadharma's Avatar
Default Re: installing the TPS
from the 2004 shop manual:
"Installation
The throttle position sensor attaches to the side of
the throttle body (Fig. 64).
(1) The throttle shaft end of the throttle body
slides into a socket in the TPS (Fig. 66). The socket
has two tabs inside it. The throttle shaft rests
against the tabs. When indexed correctly, the TPS
can rotate clockwise a few degrees to line up the
mounting screw holes with the screw holes in the
throttle body. The TPS has slight tension when
rotated into position. If it is difficult to rotate the
TPS into position, reinstall the sensor with the throttle
shaft on the other side of the tabs in the socket of
the TPS. Tighten mounting screws to 6.2 Nm (55 in.
lbs.) torque.
(2) After installing the TPS, the throttle plate
should be closed. If the throttle plate is open, install
the sensor on the other side of the tabs in the socket.
(3) Attach electrical connectors to the throttle position
sensor."
Installing new gas door metalcruiser General PT Cruiser Discussions 2 15 Jan 2012 10:12 pm
Installing an Alarm arkansascarnut Sound and Security Forum 1 24 Feb 2009 06:20 am
Installing New Antenna DestroyerMD Exterior Accessories Forum 1 11 Jun 2005 10:40 pm
Help w/ Installing hangtym3 General Turbo Discussions 2 14 May 2005 05:13 pm
installing a cd player David Denbigh Sound and Security Forum 4 03 Jan 2002 08:05 pm
