Crank Thrust Bearing
Old 09 Feb 2012, 06:08 pm
Default Crank Thrust Bearing
Folks,
Is there any sort of fix or upgrade regarding the Crank Thrust Bearing? Just had the joy of having my crank oil seal come out twice in less than a month. After seeing multiple posts about crank end play knocking out oil seals, I had my mechanic check my crank (over .02" end play). Took bottom off engine and found thrust bearing wiped out on one face and crank side chewed up. Surprised to see that Chrysler only puts a thrust bearing on the top half. I have always seen a top and bottom on other cars.
Is there some sort of upgraded Thrust Bearing/Crank upgrade to fix this once and for all.
Thanks
Old 09 Feb 2012, 09:08 pm
UptownSport's Avatar
Default Re: Crank Thrust Bearing
bad oil leak
Perhaps we could keep it all on one thread?
Good info, I've never seen this new crank!!!!
Pics?
Old 10 Feb 2012, 09:38 pm
Are the crankwalk engines in stick shift cars? That is the case where I've seen it on other brands. Pressing on the clutch pedal pushes pressure plate against the flywheel, loading the thrust bearing. It's especially damaging during engine startup where the oil pressure hasn't built up. If it's a stick shift only issue, that would explain the low percentage of total engines that have the failure.
Crank Sensor ejstith General PT Cruiser Discussions 3 11 Nov 2010 02:41 pm
slow crank ptguy69 Tech & Performance Forum 2 18 Sep 2010 03:04 pm
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Cold Crank, 2nd Try. zzzhuh Turbo Performance 10 11 Jun 2003 10:45 am
