crankshaft position sensor veses knock sensor
Old 12 Feb 2012, 09:16 pm
Default crankshaft position sensor veses knock sensor
05 pt 5 speed non turbo having trouble finding the crankshaft sensor the manuals say its above the oil filter but its not so i did more looking at other pt web sites (i know mistake) and they show it being near the starter in the front of the engine but when i looked all i found was the knock sensor where the heck is the cpk sensor or are they one in the same cause when i went to check prices on the sensors they look totaly different
Life is great when rolling with a beagle dont leave home without one
Old 13 Feb 2012, 12:15 am
UptownSport's Avatar
Default Re: crankshaft position sensor veses knock sensor
Yes sir,
Both are correct, your year crank sensor happens to be behind the starter.
Old 13 Feb 2012, 01:30 am
so then where exactly is the knock saensor orare they one in the same
Old 13 Feb 2012, 05:54 am
The knock sensor is also near the starter on the front side of the engine. They are different.
Old 13 Feb 2012, 08:35 am
Buy a crank sensor.
The sensor you'll want to replace will look just like it.
Old 13 Feb 2012, 05:53 pm
fy9-03pt's Avatar
I replaced my crankshaft position sensor Yesterday. It went into Linp mode when I pressed on the Gas. Kept getting an engine light I hope its fixed.Then got my Interrior light working after not having one for about 110,000 miles. Went to Florida March 1st, 2003 when I got back it wasn't working .
Robert
Old 13 Feb 2012, 06:10 pm
thanks all dont know why i didnt bring the question to u all earlier i have been a member for sometime now u will all be first in the future.
crankshaft position sensor ab33arch Tech & Performance Forum 23 31 Mar 2017 04:13 pm
Crankshaft Position Sensor Replaced But.. SuperTroy General PT Cruiser Discussions 10 01 Jan 2013 06:20 pm
Need help in finding Crankshaft Position sensor john1561 Tech & Performance Forum 19 25 Nov 2011 01:56 pm
crankshaft position sensor, fuel pump??? HELP!!!! Amy Tech & Performance Forum 10 23 Jan 2011 07:30 am
