Double Checking Spark Plugs
Old 14 Feb 2012, 04:29 pm
Wink Double Checking Spark Plugs
Hello everybody....hope everybody is feeling good good good.......
...Okay....so, I own a 2010 PT Cruiser Classic...I recently purchased a set of the Magnecor KV85 Competition (8.5mm) plug wires for the car and wanted to double check I understand what I've read from all the MANY posts regarding spark plugs.
....it sounds as though this forum would recommend a double platinum spark plug....is that a correct assumption?....any recommendations over which brand I should purchase...there are the Champion Double Platinums and the NGK Double Platinums....NGK are more expensive but still not a deal breaker by any means.
...On those spark plugs will I need to set the gap to .40 ? ...because it sounds like those spark plugs come gapped at .52 I believe.
....and last...again....the iridiums are not a better choice...is that correct?
Strand
Old 14 Feb 2012, 04:40 pm
Default Re: Double Checking Spark Plugs
Strand,
Everybody's got their own recommendations. Champion Double Platinum #7570 is what I'm running for the last 60K and there's no hesitation and starts up first try every time. Yes, you'll have to drop the gap to .040in
Old 14 Feb 2012, 04:52 pm
Ditto!
Spark plugs Tom SLippy Tech & Performance Forum 16 08 Mar 2016 09:50 am
Autolite Double or Single Platinum Plugs? falconut Tech & Performance Forum 2 08 Jun 2010 03:19 pm
looking for spark plugs YoungCruiserrr Tech & Performance Forum 11 10 Aug 2009 11:26 am
Double platinum plugs? Rt66Bob Tech & Performance Forum 2 14 Mar 2009 09:11 am
NEED to know what spark plugs to get ptcruzin42 Turbo Performance 11 12 Aug 2003 12:50 am
