Motor Mounts
Old 15 Feb 2012, 01:11 am
Exclamation Motor Mounts
So, my girlfriends 02 Limited PT (in signature) has been shaking like crazy and I figured I'd do some research and I'm going to go ahead and assume it's motor mounts. Today I had her rev the engine and shift and the engine would move freely. I know OEM's are crap and I know that on a turbo the Bwoody's and AGP are great, but will they fit her Non-Turbo? Are all PT motor mounts universal?
If not, where is a good site to find some? I have done my research and a lot of people just ask how to replace and I just want to know where to get them.
Thanks for the look over, it's much appreciated!
(Even if it is not the motor mounts, it couldn't hurt to get them changed considering her PT is sitting at 192k miles)
Wife's White 2002 Limited: Konig 17" Rims, 5000k White HID Head Lights,
My Red 2003 GT: Sold.....
Old 15 Feb 2012, 01:29 am
Default Re: Motor Mounts
They will fit.
Old 15 Feb 2012, 01:33 am
Just look for the '03-'05 neon srt4 motor mounts. They are all over the net. The srt4 tranny mount will not fit the PT, just the motor mounts.
Old 15 Feb 2012, 07:51 am
If you are putting them on a car with an automatic tranny, you are going to hate them...The engine will shake like crazy while in "D", specially when you stop in a traffic light and with the AC on.
Old 15 Feb 2012, 01:01 pm
For the automatic just go with the stock srt4 motor mounts.
Old 15 Feb 2012, 07:45 pm
Smile Re: Motor Mounts
Alright, I really appreciate the quick feedback, I'll search for replacement motor mounts on srt4!
Also (a little off topic), are the alternator belt, serpentine belt and timing belt the same thing?
Since she's coming around 200k I am making a list of things to get.
1. Motor Mounts (Srt4 stock)
2. RockAuto Timing Belt Component Kit W/Water Pump
3. Brakes
4. Re-Gap Spark plugs (Change if needed, checking this weekend)
5. Oil Change (regular maintenance)
Anything else I may be missing?
Old 15 Feb 2012, 08:12 pm
mdfrodolives's Avatar
Jimmy, you're talking three different belts. Also, try Autozone for your upper and lower struts (motor mounts). I put in their "Duralast" brand and they don't shake at idle--but they do, in fact, last ....
Tim
Old 15 Feb 2012, 09:02 pm
fabreezai's Avatar
3. Brakes
I would make sure the timing belt kit comes with the tentioner and idler pulley. As well, while you are in there, get the 2 cam shaft seals and front crank shaft seal and replace them with that many miles. They are only about $6-8 each and are easily assessable while you are doing the timing belt. Just my 2 cents.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 15 Feb 2012, 09:23 pm
X 2 make that 4c
Old 15 Feb 2012, 10:01 pm
Question Re: Motor Mounts
Are these all the belts I will need?
Alternator: Master Pro Belt/Hose K040345 - V-Ribbed Belt | O'Reilly Auto Parts
Power Steering (Referred to as "Serpentine"? Gates Micro-V ATŪ K040560 - OEM Quality Serpentine Belt | O'Reilly Auto Parts
Motor mounts going bad wasmussen General PT Cruiser Discussions 31 07 May 2015 07:23 pm
motor mounts bogaz Tech & Performance Forum 17 26 Dec 2011 10:47 am
Motor mounts sdwilson General PT Cruiser Discussions 4 13 May 2011 10:15 am
Motor mounts sdwilson Tech & Performance Forum 8 03 Aug 2010 12:49 pm
Motor mounts saldagus Tech & Performance Forum 6 15 Apr 2009 09:06 am
