Oxygen sensor & idle air control - MOPAR or aftermarket
  • 1 Post By CREWZIN
Old 15 Feb 2012, 09:12 pm
Default Oxygen sensor & idle air control - MOPAR or aftermarket
'01 non turbo - I plan to replace the oxygen sensor and idle air control. I've read recently on this forum that MOPAR electrical parts are superior than aftermarket. Does this apply to these two items as well? Does anyone have experience or advise?
Old 15 Feb 2012, 09:50 pm
fabreezai's Avatar
Default Re: Oxygen sensor & idle air control - MOPAR or aftermarket
IMHO, from what I have read here and listened to, when it comes to ANY kind of electronic sensor/part on our PT's, always replace with OEM. Why? I don't know, just took the advice and never had a problem. Asked Mater many times about it but never got an answer other than "Purring" so I never took the chance on aftermarket.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
I've used BOSCH 02 sensors on both up and downstream and never had a problem. I'm usually the one who tells everyone to use MOPAR electrical parts but don't think the 02 sensors fall into that category. Not sure about the IAC, but it is electrical and I would use only MOPAR for that one if I had to change it.
The reason for the MOPAR/Chrysler parts (as I understand it) is that after market parts are made to look and work like OEM parts but are made cheaply from inferior parts and either don't work at all or don't last very long because of the cheap material they are made from.
Oxygen Sensor luvmypt Tech & Performance Forum 15 23 Aug 2017 04:32 pm
oxygen sensor suzysparkles General PT Cruiser Discussions 1 18 Nov 2011 01:11 pm
Oxygen sensor myanez Tech & Performance Forum 11 28 Jul 2011 08:42 am
Oxygen sensor Laural Tech & Performance Forum 20 26 Jan 2011 07:47 am
Oxygen Sensor??HELP?? mjb457 Tech & Performance Forum 0 22 Jul 2007 09:56 am
