timing belt quote
Old 17 Feb 2012, 08:57 pm
Default timing belt quote
Estimate
Bill To
Bill Bjork
Plate
204
Anoka, MN 55
Description
2006
USA
Make
Chrysler Pt Cruiser Base
Engine
L4-2429 2.4 USA
Odometer
Phone
(763)
VIN
Email
billbjork@comcast.net
PO #
N/A
Work Order #
0000002529
Invoice Date
Feb 13 2012
Invoice #
N/A
Appointment
Feb 13 2012 3:30 pm
Svc Advisor
Doug, Benson
Promised
Feb 13 2012 10:30 pm
Technician
Not Assigned
Services Requested
Timing Belt - Replace
Timing Belt Kit With Water Pump
1.00
Units
$355.20
/ Unit
$355.20
M
Remove & Replace Timing Belt And Water Pump
$598.06
Sub
$953.26
Cooling System Flush (Global)
Add a bottle of flush chemical to radiator, and run vehicle until chemical has had plenty of time to work its way through the entire cooling system. Connect coolant flush machine to vehicle and flush radiator until fluid is clean. Disconnect coolant flush machine, top off cooling system, and recheck coolant freezing point. Test drive vehicle to ensure there are no air pockets in system.
2 Step Cooling System Service Kit
1.00
Units
$19.99
/ Unit
$19.99
M
Global Antifreeze
2.00
Units
$11.98
/ Unit
$23.96
M
Labor
$80.01
/ hr.
$56.01
Sub
$99.96
Total Labor
$654.07
Total Parts
$399.15
Total Before Taxes & Miscellaneous Charges
$1,053.22
(*) Shop Supplies:
Hazardous material charges cover the cost of disposal for any waste fluids and compliance with environmental regulations as regulated by the Province, City, or the Municipal District
$24.19
M
(#) Standard Hazardous Materials Disposal
$15.00
(M) Minnesota State Tax
7.125
$30.16
Totals
$1,122.57
Estimate Comments
Estimate:
This Estimate is based on visual inspection, and does not include additional items which may be required after disassembly. Occasionally, after work is started, worn, broken, or damaged parts maybe discovered which were not evident upon the initial inspection. Prices on parts and labor are current and subject to change. All parts are assumed to be new parts, not provided by the original equipment manufacturer unless otherwise noted. Estimates are valid for 30 days.
In the case of alternators, starters and driveshafts, assume we use rebuilt products.
Date: _______________ Prepared By: _________________________
Old 17 Feb 2012, 09:09 pm
Default Re: timing belt quote
What the heck are you trying to say in your post and why post it like you did?
Old 18 Feb 2012, 01:53 pm
UptownSport's Avatar
Guessing he wants our opinion on the estimate?
High side of average for timing belt & water pump
Old 18 Feb 2012, 02:55 pm
my estimate was around $700 including recharging the A/C from a non dealer but very reputable mechanic
Old 20 Feb 2012, 02:19 pm
Cartmansnuts's Avatar
I got mine replaced last month for $900 including water pump and AC recharge.
Silver '03 NA, K&N Gen 2 Cold Air Intake, Borla Cat back 2.25 dual out, 18" Gunmetal Drag DR-19's , 225/40 ZR18, Tokico Blue shocks and struts with Eibach Pro springs. Soon (money and wife permitting) PTeazer front fascia w/ retro grill, power cowl hood and rear rollpan. In the back of my mind: Kenne Bell Optimizer II (If I can find one).
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:06 pm
