A/C issue and Tie Rod ?
Old 20 Feb 2012, 08:11 am
themadgreek187's Avatar
Default A/C issue and Tie Rod ?
First off my neighbor(certified mechanic) has always worked on my car. he knows pretty much everything on my car. this weekend we tried to replace the front tie rods and apparently u need a special tool of some sort to remove the tie rods? any ideas?
2nd my a/c has stopped working. the compressor does not kick on nor does the fan.fan was replaced not even a year ago. we found that the socket that plugs into the switch on the back of the compressor does not seem to work. he can jump the switch by grounding it which causes everything to turn on. i am guessing the socket or wire is bad. tried looking up replacement parts but no avail. any ideas?
Old 20 Feb 2012, 08:28 am
Default Re: A/C issue and Tie Rod ?
For the inner tie rods you need to use this tool.
Lisle Inner Tie Rod Tool | Wayfair
Old 20 Feb 2012, 09:13 am
thanks i appreciate it. i wonder if u can buy that locally? oreillys , autozone, etc
Old 20 Feb 2012, 12:48 pm
Outer tie rods, any body with mechanical ability can change. Inners requires a a special tool available at the parts store. Maybe can rent. On the ac did you check to see if the freon leaked out?
Old 20 Feb 2012, 04:20 pm
a/c freon has not leaked. apparently the wire connecting to the HPS must have a bad ground. he is going to see about bypassing the bad ground and just running a new wire altogether. called the Chrysler dealership and their suggestion was too buy new harness for the wiring but replacing that would be a PITA and $$$$$. car has 175k and i'm not dumping much more into it.
Old 20 Feb 2012, 04:53 pm
Don't blame ya on the harness. Might go through all the chasey grounds in engine bay. Think there is some under the battery, I think. Bet there is a ground location schematic in this forum somewhere. Its got everything else! If your not getting ground there it will show up somewhere else later.
Old 23 Feb 2012, 08:44 am
ok got the tie rods done and the car aligned. drives like brand new! now my AC issue. it appears there may be a short in the wire plugging into the High Pressure switch on the compressor. my mechanic can bypass the wire but the AC will run continuously and that won't be good. any other tricks to try as i don't wanna shell out a ton of money?
Old 02 Mar 2012, 02:07 pm
so update to my a/c issue. seems as though they are thinking my wiring harness is bad. thats $1000 im not throwing into this car. i'm cutting my losses and buying a new car. my pt has served me well since 05. too many issues down the stretch. thanks for all on here who provide useful information.
Old 02 Mar 2012, 06:25 pm
Good luck with the new ride!
Just a little issue with my PT... TheDarkAvengerX General PT Cruiser Discussions 8 03 Nov 2011 04:55 pm
Key Fob issue Motherlynn Tech & Performance Forum 22 17 Feb 2011 04:41 pm
03 GT AC issue freakengine Tech & Performance Forum 5 04 Sep 2010 10:06 pm
HID issue CYCLONE_06 Tech & Performance Forum 0 16 Apr 2009 08:00 pm
A/C issue. hermtm2 General PT Cruiser Discussions 9 26 Jul 2008 08:40 pm
