location of transmission ground strap
Old 20 Feb 2012, 08:56 pm
Default location of transmission ground strap
Can someone tell me ( or show me in a diagram) where the transmission ground strap is on a 2001 PT Cruiser?
Old 20 Feb 2012, 09:50 pm
Default Re: location of transmission ground strap
I got this answer from PT Do-It-Yourself.net
The use of braided ground straps in key locations is part of the RFI and EMI prevention strategy on the PT. These ground straps ensure adequate ground paths, particularly for high current components such as many of those found in the starting, charging, ignition, engine control and transmission control systems. One end of the engine ground strap is bolted to the engine cylinder head. The other end attaches to a bolt on the top of the strut tower. As a precaution disconnect the negative lead on the battery before re-connecting the ground strap.
Strap on Air Filter...? Heard of it. whitbyPT Tech & Performance Forum 10 01 Sep 2010 08:48 pm
Static strap hicomp Wheels, Tires, Suspension 3 21 Oct 2008 09:26 pm
Engine Ground Strap Location??? PlumCrazyMonkey Tech & Performance Forum 2 27 Jul 2007 03:02 am
Ground strap mcruz General PT Cruiser Discussions 8 26 Dec 2003 09:36 pm
BTG Intake support strap nbr10 General Turbo Discussions 23 20 Nov 2003 07:19 pm
