Wheel bearing issue?
Old 21 Feb 2012, 09:07 am
dwg12's Avatar
Default Wheel bearing issue?
Have an 06 Cruiser with 84,000 miles. Just bought it so I don't know if anything has been replaced, but, it makes a humm and slight vibration "only" when slowing down from highway speeds. Any ideas?
Old 22 Feb 2012, 03:10 pm
UptownSport's Avatar
Default Re: Wheel bearing issue?
Could be lots of things, certainly a Wheel Bearing is one of them.
A little rust on a rotor, or slight warpage could also do it.
*Usually* a wheel bearing comes into play when turning slightly.
Engine torque arms (aka motor mounts) are very common to fail, tons of posts on this
If it's only 'Slight', I'd let it be and see if it gets worse instead of chasing parts.
Old 23 Feb 2012, 06:44 pm
dwg12's Avatar
Thanks for the info.....It really reminds me of a slightly warped rotor so I'm just going to do what you suggest and let it be for now.
Tags
front brake vibration, humm
Wheel bearing!!?? jrs61282 Wheels, Tires, Suspension 0 11 Jun 2011 12:46 pm
wheel bearing and hub replecment. monitor51 Wheels, Tires, Suspension 1 21 Aug 2010 01:13 pm
Wheel bearing issue? scrisp2 Wheels, Tires, Suspension 10 26 Dec 2009 04:13 pm
which wheel bearing musicmanchuck4 Wheels, Tires, Suspension 0 08 Apr 2009 06:48 pm
