A/c Problem. Help?
Old 21 Feb 2012, 04:50 pm
Default A/c Problem. Help?
Hello, I'm fairly new. i like browsing i don't really like posting unless i can fix someones problem or if someone can fix mine.
Now, My ac doesn't work. i think i have found the problem, and its a crack in a tube. what would be a quick fix or how much would it cost to replace the tube?
Please get back to me. i would greatly appreciate it.
Ty,
RedEmma
Old 21 Feb 2012, 05:05 pm
Default Re: A/c Problem. Help?
Emma, there's really no fix for a cracked tube except to replace it. It means loosing all the old R134a and capturing it in a proper container. Usually not a home project.
Old 21 Feb 2012, 05:12 pm
Well, its just a small crack, and i've had several problems with this, and if i just replace it and just recharge it, will that work?
Old 21 Feb 2012, 05:15 pm
or what if i buy a stop leak, do you know if those stop leaks for a good amount of time?
Old 21 Feb 2012, 05:23 pm
Never heard of a stop leak for A/C but that doesn't mean there isn't any. The A/C system is under a lot of pressure, can't see how it would work.
Yes, replacing the bad part and recharging it should get you up and running as long as there's nothing else wrong.
Old 29 Feb 2012, 10:57 pm
ok so, i took it to a mechanic that i know, and he said that basically, everything is fine, and it even has free-on and it isn't lacking any. he said that the compressor is fine as well, and the whole ac system is working as it should. he said its something electrical. do you have any ideas on what it would be?
Old 01 Mar 2012, 07:11 am
You never said what year your PT is but if it's between 2001-2005 you have a black box in the engine compartment called the PDC (Power Distribution Center) and inside are fuses and relays. The No#11, 10 Amp fuse is for the A/C, you need to check that. You also have a high pressure switch on the compressor itself and a low pressure (recycling ) switch on top of the accumulator. Either one of those could be bad.
Old 03 Mar 2012, 09:09 am
Found answer-removed prev question.
Old 22 Mar 2012, 12:11 am
Crewzin, i checked the recycling switch, and i researched up in it, and it ended up being bad in someone, i went to the auto parts store, and bought a new one and it ended up working! btw, sorry for the late reply!
Old 23 Mar 2012, 12:05 am
I found a collection of questions and issues related to air conditioning on the PT cruisers and have posted it in the Tech/Perf section. Here is a copy you can download at your leisure, it may be of some help: PT Cruiser Air Conditioner Issues/Questions
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
AC PROBLEM trex118 Tech & Performance Forum 7 20 Jul 2010 05:15 am
A/C Problem blue03ptgt Tech & Performance Forum 7 09 Jul 2009 07:35 pm
Problem? deederz Tech & Performance Forum 3 04 May 2005 10:19 am
Will this cause a problem? crazie.eddie General PT Cruiser Discussions 9 24 Oct 2004 05:29 am
