Distributor question
Old 21 Feb 2012, 08:32 pm
Default Distributor question
can the distributor be adjusted a click back or forward to get the engine firing on the right beat again like you could do in older cars? If so how do you do it?
Thanks!
Old 21 Feb 2012, 08:51 pm
Default Re: Distributor question
Since we don't have a distributor that would be tough to do. "nigh on to impossible" as my grandfather would say.
You can adjust timing if you have a turbo if you have a PCM program modifier like the DSP, but it usually isn't bought just to adjust your timing. It's to expensive for just that kind of function and not for a novice.
Jerry
Old 21 Feb 2012, 09:34 pm
Question Re: Distributor question
Thanks!
If its out of time your belt had to slip. If it had a distributor you couldn't adjust all that out. Tell every body what you got going on. It might not be that bad.
:question:daytime running lights!!!:question: jrs61282 Tech & Performance Forum 10 07 Nov 2010 10:53 pm
Luggage Rack question and trailer hitch question Patrick_Dickey General PT Cruiser Discussions 5 26 Apr 2009 09:19 pm
