Tranny Issues please help!!!!
Old 22 Feb 2012, 10:31 pm
Default Tranny Issues please help!!!!
Hey guys i just bought a 2004 2.4L touring PT the transmission will work for 10 minutes and shift into 1st and 2nd and reverse and just when the car is warmed up it quits and pretends its in neutral, is this a splice wire and transmission ground problem or does the whole thing need replaced please anyone write back ASAP!!!! thanks guys
Old 23 Feb 2012, 10:19 am
Default Re: Tranny Issues please help!!!!
I'm not an automatic tranny mechanic, but to me it sounds more like a solenoid pack issue than a complete tranny issue. Just my opinion.
Old 23 Feb 2012, 12:07 pm
Where is the solenoid pack located in the car??
Old 23 Feb 2012, 12:09 pm
On the tranny under the battery. If you just bought it, why not take it back?
Old 23 Feb 2012, 12:51 pm
Because I bought it knowing the transmission was acting up and it was only 1500 bucks and it's perfect except that transmission
Old 23 Feb 2012, 12:56 pm
have you done the key dance to check for any p07## codes?
key dance=cycle key on, key off, key on, key off, key on.
any codes will show up where the odometer reading show up
i think i'd do a fluid/filter R&R
how many miles?
what color is the fluid and does the it smell burnt?
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 23 Feb 2012, 12:59 pm
Sounds reasonable except if you need a whole new tranny but if the rest of the car is good, might be a good deal.
Chromenut's guess was a good one, but the solenoid pack should set a fault code (p0700) if it was a problem. The 700 code is only generic saying there's something wrong with the transaxle and a good scanner would be needed to pinpoint the exact problem.
Old 23 Feb 2012, 02:19 pm
trans fluid is pink and has 134000 don't know if it's burnt or not
Old 23 Feb 2012, 10:56 pm
did the key dance... nothing showed up
Old 24 Feb 2012, 05:28 pm
The guys are right, if the solenoid was running a defect you'd get an error code. As to the color, it sounds right. You should just smell the fluid, if it has a really burnt odor to it then it needs changing.
02 PT was driving great then *poof* Tranny issues...ugh dbittenbenderjr Tech & Performance Forum 1 02 Aug 2011 10:55 pm
tranny.... superpug666 General Turbo Discussions 2 30 Sep 2009 08:48 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
yea it's the tranny! atcocruiser Tech & Performance Forum 6 31 Dec 2007 08:36 pm
02 tranny azmexicali Tech & Performance Forum 2 17 Nov 2007 11:38 pm
