Power steering hose leak, help!
Old 24 Feb 2012, 12:53 pm
Default Power steering hose leak, help!
Well yesterday I went to check out a customers 05 PT cruiser N/A. She told me that the power steering gave out on her all of a sudden. I soon as I saw the car, I noticed it was leaking. I asked her about the leak but she told me that it was the first time it leaked that much. I oped the the hood and the reservoir was empty. Since all I saw from the top was P/S fluid on top of the a/c compressor, I crawled under for a better view. Once I removed the plastic cover, I still couldn't tell where it was leaking from so I added a bit of P/S fluid to the reservoir and started the car. I saw that it was leaking from the hose where it connects to the pump, between the metal hose and the hose nut fitting. I removed the line and saw an o-ring, I changed the o-ring put everything back, turned it on and it was still leaking so this is where I'm stumped. Can anyone help me?....sorry for 1st long post!
Old 24 Feb 2012, 03:27 pm
UptownSport's Avatar
Default Re: Power steering hose leak, help!
Geez, it sounds like you've found the leakpoint, attempted to repair it,
and the repair didn't work for some odd reason.
Was the original o-ring ripped?
Let me get this straight;
You're a mechanic and actually saw where it was leaking. At the point where the PS hose attaches to the pump.
You pulled the line and saw that there was an "O" ring there and you replaced it. It still leaked.
So you just happened to have the correct "O" ring with you that fit the PT power steering pump instead of having to go to the dealer to get it?
Next "if I was a mechanic" I would then go and get the real "O" ring and try it again. If you then see that it is still leaking I would replace either the hose or the PS pump. The most likely and of course easiest choice, would be the hose first.
tirs
Jerry
Old 24 Feb 2012, 04:42 pm
Ihats why I been scratching my head and no it wasn't!
tirs
Jerry
No, I didn't have the same o-ring! I tried the stealership but they don't have just the o-ring and they told me I would have to buy the whole hose, thats why I tried a regular o-ring first.
Old 24 Feb 2012, 05:35 pm
Sorry, duplicate post.
Old 24 Feb 2012, 05:38 pm
Thats the high pressure side and If you didn't use the correct o-ring (Apparently thats should read "complete line") it will leak. So now you've got to duplicate your work and go back in again and replace the hose.
Jerry
Old 24 Feb 2012, 06:32 pm
I sorry we are not all perfect in the eyes of some. But I commend you for trying to understand just exactly why it failed. If you don't understand the why you can't fix it, you end up throughing parts at it till you get lucky. Sounds like a dealership doesn't it. Oh forbid I get my grammar wrong here. I think someone might have used a smaller diameter o ring to start with and you installed the same size with the same result. Use a thicker one & rub a little oil on it before you insert fitting. Make sure you use o rings compatible with power steering fluid.
Old 24 Feb 2012, 08:53 pm
That's certainly likely, the O-ring was too small.
We assume that,
it's been untouched
the replacement o-ring was at least an approximation of what was needed.
If it were, you'd see it ripped.
There's also the possibility that line was removed and isn't seating for some odd reason- I'd doubt the 'packing' nut would seat, tho
Old 24 Feb 2012, 09:10 pm
We assume that,
it's been untouched
The line would have to be obviously messed up to keep it from going all the way in. I'd think.
He also said in the beginning the owner said it didn't leak this bad before.
Old 24 Feb 2012, 10:10 pm
We assume that,
it's been untouched
The owner told me that nobody has worked on the car other than me! When I put the line back in, it went in without any problems and the nut turned smoothly!
Like I said, it went in smoothly. What I'm still trying to figure out is what made it fail in the first time. There is no way that the thread would of failed.
Is there anyway that there is crack on the metal line after the o-ring?
replace power steering pressure hose joeus Tech & Performance Forum 6 14 Dec 2014 08:42 pm
Power steering high pressure hose leak. canbug Tech & Performance Forum 2 13 Mar 2011 08:16 pm
Replacing Power Steering Pressure Hose wapasha General PT Cruiser Discussions 0 20 May 2010 09:08 am
Need Power Steering hose, Reservoir 340x Classifieds: Want To Buy 1 07 Jul 2009 11:07 pm
Power Steering Hose Needed 340x Classifieds: For Sale/Trade 1 29 Jun 2009 04:53 pm
