SPI LINE IS NOT COMMUNICATE ECM
Old 24 Feb 2012, 02:16 pm
Post SPI LINE IS NOT COMMUNICATE ECM
I NEED THE CODE IS PO6O1 SAYS INTERNAL FAULT ,UNABLE TO COMMUNICATE ON THE SPI LINE,?WHER IS THE SPI LINE..I WAS TOLD IT MIGHT BE A INPUT SENSOR,,?WHICH SENSOR..OR ELEC CIRCUIT WHAT WOULD I DO THEN?OR LAST A FAILED ECM WHERE IS THE ECM THANK U SO MUCH IF U COULD HELP
Old 24 Feb 2012, 02:37 pm
Default Re: SPI LINE IS NOT COMMUNICATE ECM
The ECM is the silver box attached to the firewall in the engine compartment in front of the driver. Usually a P0601 is fatal and requires a replacement. You can reset the ECM by taking off the negative battery cable for about 5 minutes. Step on the brake pedal while the battery is disconnected to get rid of any residual charge and put everything back together. If the code was just a fluke, everything will go back to normal. If not the code will come up again and you'll need a replacement computer.
P.S. Please don't type your post in all capital letters. On internet protocol it's like shouting. You can use capitals to emphasize somethng but not the whole post. Thanks.
Old 24 Feb 2012, 02:59 pm
And you should ask your question once and in only one category. We WILL all see it.
Jerry
Old 24 Feb 2012, 03:05 pm
Got the others Jerry. Didn't see them. Thanks.
thank you for your input i will try that, and sorry about THE CAPS i wasnt paying attention thank u again
Old 24 Feb 2012, 03:07 pm
im a new member and i wasnt sure if i was doing it right
vacuum line bhunt41 Tech & Performance Forum 0 02 Jan 2011 03:19 pm
California Smog Test 2006 Car does not Communicate with the Testing Appratus dc1152 Western PT Forum 0 24 Oct 2010 02:33 pm
on-line videos 4SPEED General PT Cruiser Discussions 2 30 Oct 2006 05:19 pm
Best product line? GstnNole The Detail Shop 7 30 Apr 2004 11:22 pm
what's this line? OurPTGT General Turbo Discussions 3 10 Jul 2003 04:47 pm
