Engine Mount Compatability
Old 24 Feb 2012, 06:31 pm
Default Engine Mount Compatability
I've seen the engine mount topic inside-out and upside-down... for 01-06 models...
I have a 09 PT that's showing some considerable drivetrain rock and I'm looking to either add inserts, or replace altogether, inserts preferably(cheaper,transferable). Can I safely assume that the mounts are consistent throughout the whole decade?
Old 24 Feb 2012, 07:02 pm
Default Re: Engine Mount Compatability
Yes, but inserts as far as I know are not available. Solid or stock is basically your choices.
Old 24 Feb 2012, 07:51 pm
If you're talking abou the upper and lower torque struts then yes, There are several companies that market inserts for them. A couple that come to mind are "Energy Suspension" and "Prothane". They are the two that seem to be the most popular. Prothane has two grades of firmness. Their black colored inserts are for the street. Their red is for racing. You can also just remove the struts and if the rubber isn't broken you can simply fill them with one of the better grades of home window seam filler. Bunches of owners have went that route, but just as many have done the inserts. Personally, I wouldn't go the filler route.
Personally, I just installed the OEM SRT-4 struts. They are stronger than the stock PT struts and don't produce any noticable vibration if you install them at the correct measurements. Some have gotten lucky and got the measurements right by accident, but I wouldn't rely on that happening.
Jerry
Old 24 Feb 2012, 11:51 pm
mdfrodolives's Avatar
Grease, I bought my struts at AutoZone. They were Duralast. They were the same struts (part number) for a PT or SRT. I'm pretty happy with them--not too much vibration at idle, and the motor doesn't rock anymore. And they have a lifetime guarantee if they break down like OEM ones (which have no guarantee).
They're also fairly cheap.
Tim
Old 25 Feb 2012, 09:47 am
Tim
They won't last a lifetime so might be worth the extra $ over on line mounts.
Old 26 Feb 2012, 02:24 pm
Thanks, all.
Had my wife run it through the gears while I looked at the top and lower torque mounts.. Turns out that the lower is broken for sure, not sure about top.
Ended up buying the Anchor brand mounts from Rockauto, even though I know not everyone was happy with their quality. Paid just under $40 total for top and lower, expedited shipping figured in.
I think I'll get them on as a short-term fix, then add the Energy Suspension inserts to beef them up when I can afford it in a month or two.
Tags
engine mount, motor mount
Top Engine Mount! mdfrodolives Tech & Performance Forum 6 18 Apr 2011 08:04 pm
need right engine mount bracket csd Classifieds: For Sale/Trade 6 17 May 2009 07:45 pm
Lower engine mount ejacko Tech & Performance Forum 5 21 Mar 2009 12:01 pm
ok how do you get the top right engine mount out??? llcelebrity Tech & Performance Forum 6 20 Feb 2009 11:44 am
Engine Mount Problems chris1916 Tech & Performance Forum 1 15 Jan 2009 03:19 pm
