Can the PT engine be pulled from the top?
Old 26 Feb 2012, 12:06 am
Default Can the PT engine be pulled from the top?
I have a 2001 PT Cruiser and want to do an engine rebuild. However, it seems most literature I've read states the engine has to be removed from underneath the car. I don't have access to a lift and don't know how I would be able to raise the car high enough to be able to remove the engine (at home). Has anyone actually pulled the engine out from the top? If so, how hard is it to do? Any tips would be appreciated.
Old 26 Feb 2012, 10:03 am
Default Re: Can the PT engine be pulled from the top?
If you can lift the engine out of the engine bay. Why can't you lift the front end of the car off the engine the same way?
Old 26 Feb 2012, 12:24 pm
its much easier to drop the motor plus tranny from bottom take the after u undone the motor mounts and both axles set the body down on some 2/10s undo the trans back mount should be able to raise the body up and slide the motor out:
How often do y'all get pulled over??? Darkside7789 Sound and Security Forum 6 14 Jun 2011 09:27 pm
Pulled the Trigger RaineMan Welcome New PT Cruiser Members 9 29 Apr 2011 09:22 am
Pulled the trigger Danno General PT Cruiser Discussions 16 10 Sep 2010 11:12 am
