starter wire
Old 26 Feb 2012, 11:48 am
Default starter wire
I just put in a re built motor and i need to know were does the green wire that is near the starter go?
Old 26 Feb 2012, 12:01 pm
Default Re: starter wire
Near the starter or attached to the solenoid that's on top the starter? If that's the one it goes to a fusible link and then to the alternator. If your going to do work like that, a Haynes or Chilton Manual helps out alot.
Old 26 Feb 2012, 12:20 pm
Also And I keep forgetting this one If you have a digital camera or phone camera take pictures of the different things you will be removing. That way when you forget were it goes you can go back and look at the pictures.
How do you remove the starter penelope Tech & Performance Forum 12 16 Dec 2014 11:58 am
starter? jmikesch General PT Cruiser Discussions 5 07 Jan 2012 02:15 pm
Bad starter?? jdmickies Tech & Performance Forum 8 06 Sep 2010 11:01 pm
Possible bad starter morrises Tech & Performance Forum 7 17 Jun 2008 09:07 pm
Remote Starter for 03 GT Indynick General Turbo Discussions 6 22 Dec 2004 03:44 am
