traces of oil in the intake manifold?
Old 27 Feb 2012, 01:32 pm
dunnboy's Avatar
Default traces of oil in the intake manifold?
Is this normal I was replacing my spark plugs and oh God they needed it and noticed when I took the manifold off around the seals which appeared good there was some oil along with a little on the inside and I noticed a little on my throttle body my car is an 03 n/a so please let me know what you guys think
Old 27 Feb 2012, 01:53 pm
Default Re: traces of oil in the intake manifold?
that's normal
Old 27 Feb 2012, 02:44 pm
dunnboy's Avatar
Thanks for letting me know I wasn't sure if I should be worried or not lol
Old 27 Feb 2012, 04:33 pm
Like Xtrm said, its normal but check in the bottom of your air filter box and clean up any oil accumulation that might be in there. It comes from the oil-born air from the crankcase and is normal for all cars. It's the nature of the beast. You can put a catch-can in the PCV hose exiting the cam cover but that is overkill if you're just a normal, everyday PT driver.
Jerry
Old 27 Feb 2012, 06:44 pm
dunnboy's Avatar
No airbox here just a cold air intake but I get what you're saying thanx
Old 27 Feb 2012, 09:32 pm
mdfrodolives's Avatar
Dunn, mine had oil inside, too. I just like to think that it gives my valves a little extra lubrication. It makes me deal with the issue, anyway.
I think it comes from the PVC valve, though. In fact, when I changed my PVC valve the extraordinary oil consumption I had had since about 2005, became a thing of the past. Now I lose only a half quart between oil changes (3000 miles). Before the new PVC valve I'd use a good quart per thousand miles.
So if you think that oil is way too much on the inside of your upper manifold--and you're using too much oil, then change your PVC valve. But if you're not using a lot of oil, just let it be.
Tim
Old 27 Feb 2012, 10:36 pm
dunnboy's Avatar
Yeah I noticed while taking the hose of my PCV that it was loose odd I've never changed it so I tightened it it had me wondering why it'd be that loose I mean I could've taken it out by hand but I just shrugged it off and tightened it ill be checking it again soon to make sure all is well
Old 27 Feb 2012, 11:04 pm
Change the thing, it's to cheap not too!
Old 28 Feb 2012, 05:04 am
dunnboy's Avatar
Busted I just might have to it'll give me a 5 minute thing to do anything to keep my hands busy keeps me happy
DUNNBOY
03 N/A CRUISER
Old 28 Feb 2012, 09:21 pm
Make sure you use a good thread sealant (suitable for plastic threads, by the way) on the PCV valve threads. And don't overtighten it (it can crack the mainfold). Also, get a new hose from the dealer (it has all the right bends and consistancy). My old hose at 75,000 miles was cracked on the ends.
Tim
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
intake manifold??? PTcruzer02 Turbo Performance 5 26 Dec 2008 10:58 pm
Intake manifold discovering06 Tech & Performance Forum 1 26 May 2008 05:37 pm
Gas in intake manifold bigdangerous24 Tech & Performance Forum 9 16 Mar 2008 08:32 pm
intake manifold milPT Tech & Performance Forum 5 24 May 2004 03:03 pm
