fuel injectors
Old 28 Feb 2012, 10:29 am
dunnboy's Avatar
Default fuel injectors
Now I don't see this in the how to section which is great by the way but how would someone go about changing injectors? And is there a way to test and see if they're clogged thanx for the help in advance love my pt but they sure are puzzle like
DUNNBOY
03 N/A CRUISER
Old 28 Feb 2012, 10:39 am
Default Re: fuel injectors
You can get them cleaned, tested and adjusted here:
SouthBay Fuel Injectors New OEM and Remanufactured, Injector Cleaning and Flow Testing Service.
Me and a few PT guys had them done there with great results and is only $60 for all four.
Old 28 Feb 2012, 11:08 am
What makes you think they are clogged and just for giggles, what plugs and wires did you use? Also, what did you gap the plugs at? It should be .040 or less.
Also/also, Is that a "fart can" I see in your profile? I'll heed my mothers words on that one.
Jerry
Old 28 Feb 2012, 11:28 am
dunnboy's Avatar
I don't think they're clogged just curious and didn't see it and I just put mew plugs in as the old ones I think were never changed since they put the new engine in around 07 or 08 Yikes they had a nice groove in them and lord help me if I can remember what plugs I put in they were 6.99 a pop at advance auto parts supposedly the best ones in stock and I have stock wires money's a little tight right now and.......yes that's a fart can but I love the deep rumble that comes out of it
DUNNBOY
03 N/A CRUISER
Old 28 Feb 2012, 11:34 am
dunnboy's Avatar
Just looked at the receipt it only says iridiums I have to close the gap on them a little I'm not sure why I didn't when I put them in what's the easiest way of doing that without damaging them?
DUNNBOY
03 N/A CRUISER
Old 28 Feb 2012, 11:35 am
Guess they stopped teaching punctuation in school nowadays.
If "they" never changed the plugs, it's a good chance "they" never changed the wires either. You should have put a new set in with the plugs. The injectors rarely fail but can get plugged up. Throw in a bottle of Chevron Techron into the gas tank. You didn't say your having any problems so why suspect the injectors are bad?
As far as your "fart' can muffler; if it's the type that's almost see-through with very little or NO back-pressure, that can lead to problems on it's own. The PT engine needs a certain amount of back-pressure to run well.
Old 28 Feb 2012, 11:52 am
dunnboy's Avatar
I don't suspect the injectors being bad just curious is all I take great interest in anything that has to do with an engine. What would you suggest as far as mufflers go a thrush, dynomax something along those lines? The people I'm referring to as "they" are the people from the collision repair shop
DUNNBOY
03 N/A CRUISER
Old 28 Feb 2012, 01:03 pm
DynoMax is good I have one myself but if you like the way it sounds and there's some sort of muffler inside the one you have, that will be good enough to create the back-pressure that's needed.
Old 28 Feb 2012, 01:28 pm
dunnboy's Avatar
Nope its straight through so ill look into a new muffler wheni have the extra $$ if I would have known pat's needed back pressure I would've gotten an actual muffler thanx for your input its much appreciated
DUNNBOY
03 N/A CRUISER
WTB Fuel Injectors for stage1 muzicmax Classifieds: Want To Buy 1 10 May 2011 10:44 am
Fuel Injectors Kawizx9r Classifieds: Want To Buy 0 13 Nov 2010 03:11 am
Change FROM stock fuel injectors snakepitt1 Tech & Performance Forum 9 20 May 2006 03:12 pm
Stock PCM and Fuel Injectors ptcruzin42 Classifieds: For Sale/Trade 0 08 Aug 2005 07:35 pm
Fuel Injectors rzeigler@cfl.rr.com Turbo Performance 2 12 Apr 2005 08:18 am
