Best tool to remove IAC
Like Tree2Likes
  • 1 Post By sscanlan
  • 1 Post By rcktpwrd
Old 01 Mar 2012, 11:20 am
Default Best tool to remove IAC
I know the two screws holding the IAC on my 2002 PT cruiser are T-20 Torx screws. My question is with little space behind them what is the best tool or method my socket seems to be too big.
Old 01 Mar 2012, 01:40 pm
Default Re: Best tool to remove IAC
pick up a t-20 screwdriver. there's not a lot of torque you have to worry about.
Old 01 Mar 2012, 03:19 pm
I used my 1/4" drive Craftsman ratchet and a 1/4" drive Torx T-20 bit, and was able to loosen the screws up enough that I could take the bit off of the ratchet and use it to back the screws out manually. It was a little tight, but it worked. I put a little WD-40 on the screws before I re-installed them, and that helped as well. Pulling the rubber weatherstripping off of the lip behind the IAC also gave me a little more room to maneuver.
mnahmnah likes this.
Old 01 Mar 2012, 06:49 pm
I used a screwdriver torx and a ratchet wrench
Old 09 Jan 2013, 09:07 am
mnahmnah's Avatar
I'll have to find me one of those torx bits. I can't wait to clean it up (the iac) and see if that helps. Right now car chugs so hard and stalls that it's not safe to drive.
I'm wondering if one of these folding torx key sets would work well. It would allow an angle less than 90 degrees between the key and the handle.
http://www.homedepot.com/h_d1/N-5yc1...1#.UO2_Q3eOy-0
2001 LE, 168,000 miles.
One of the split seats went into a dumpster in Tulsa. The arm rest unscrewed and fell off. It's on its 2nd timing belt. Surviving the Upper Peninsula winters.
Old 09 Jan 2013, 07:03 pm
mnahmnah's Avatar
Actually they didn't have the set pictured when I got there (liars)... But I found this nifty little tool with a t15 and a t20 bit plus more. It's a little short on the handle length, but I think it'll work how I need it to.
Old 09 Jan 2013, 08:10 pm
rcktpwrd's Avatar
I would just pull the entire throttle body off and clean that too...
rob342 likes this.
Joel
www.rcktpwrd.com
How To Remove Front Seats & Remove Or Add Drawer Dill Interior Accessories Forum 20 16 Jul 2014 09:38 am
Looking for inner tie rod tool fuzzy749 Tech & Performance Forum 0 22 Oct 2011 05:24 pm
Inner tie rod end tool? bobdole369 General PT Cruiser Discussions 6 17 Sep 2010 09:28 pm
Tool kit for PT muzzle17 General PT Cruiser Discussions 15 08 Apr 2010 07:36 pm
