Repairs to 2005 Turbo Convertible
Old 03 Mar 2012, 12:32 pm
MimisMom's Avatar
Unhappy Repairs to 2005 Turbo Convertible
Last weekend I noticed that the AC was not cooling, & since I needed an oil change, I thought I'd take it into the shop for a check up. 82,000 miles. Last year the engine mounts were replaced.
Monday the car wouldn't start & I had to get jumped to get to the shop. Here is the list of what was discovered:
New Battery, Timing Belt, Crankshaft Seal, Oil Pump Seal, Valve Cover Gasket, AC Hose & Recharge System, Water Pump, Antifreeze Coolant, Oil Change, Brake Light & there's a hairline crack at the flange of the gas tank where the hose attaches. $2,500 for parts & labor. Just thought I'd post this for other owners.
Old 03 Mar 2012, 04:38 pm
Default Re: Repairs to 2005 Turbo Convertible
Old 03 Mar 2012, 09:06 pm
MimisMom's Avatar
Wink Re: Repairs to 2005 Turbo Convertible
Thank you, thank you. A bit of sympathy is always appreciated.
MM
Old 03 Mar 2012, 10:09 pm
Dill's Avatar
Was the timing belt broke? You could possibly go a bit without the timing belt replaced if you wanted... Thatd also remove the waterpump and coolant too, aso its easy to diy the ac recharge and the battery change.
Glad ur pts in good shape now if u got it fixed tho!
Old 04 Mar 2012, 10:11 am
MimisMom's Avatar
Have had the oil leaks for a year and put that off. Now the water pump is kaput, and since they have to tear into it to get to the water pump, it seemed to make sense to tackle the timing belt, that's not quite right now, rather than spend the money on labor twice.
MM
Old 04 Mar 2012, 10:32 am
GinPa's Avatar
Did you keep up with maintenance using the right oil and coolant? I think having the timing belt done too was a great idea. $2500. is a lot to put out at one time. I like your moons and white walls
2005 GT convertible/turbo
47000 miles
Oil at the bottom of 2005 Turbo Convertible air box Deen General Turbo Discussions 4 22 Sep 2011 11:55 pm
2005 GT H.O. Turbo Convertible spotman Welcome New PT Cruiser Members 4 28 Aug 2011 04:07 pm
How can I settle a 2005 GT Turbo Convertible down? HO_Turbo Tech & Performance Forum 1 17 Apr 2011 06:30 pm
2005 PT Turbo Convertible Problems tempter805 Turbo Performance 2 23 Jul 2010 09:01 am
2005 PT Cruiser Convertible Turbo dmoon64 Classifieds: For Sale/Trade 0 21 Sep 2009 03:34 pm
