code reads po300
Old 03 Mar 2012, 04:49 pm
Send a message via Yahoo to echillie1
Default code reads po300
I'm getting an error code po300 wich means misfire,any suggestions?
2004 pt 5 speed with turbo.
Old 03 Mar 2012, 04:53 pm
Default Re: code reads po300
How old is your plugs, wires & did you get gas at a strage place?
Old 03 Mar 2012, 05:12 pm
Hello there,
Yes,plugs & wires have been changed a month ago gapped @ .050 using champion copper plugs & mopar wires.
Old 03 Mar 2012, 05:15 pm
Sorry forgot to post chevron gas 87.
Old 03 Mar 2012, 05:25 pm
Hello there,
Yes,plugs & wires have been changed a month ago gapped @ 0:50 using champion copper plugs & mopar wires.
I think the setting has been changed to 40. You might want to check to be sure. If your running a turbo might want to go high test. At the very least run some injector cleaner through it.
Old 03 Mar 2012, 05:34 pm
Hello there,
If you're a 2004 "turbo" you shouldn't be using 87 octane. We DO NOT recommend Mopar factory wires unless they are the "BLUE" performance wires. The champion coppers were a good choice. The plug gap should be no more than .040 per a TSB that was issued in 04. And most importantly CHROME, if you're reading this, can you post the entire contents of a TSB if I supply the number or can anyone else here? It is concerned with "idle fluctuation" (misfire) that result in codes P0300 and P0301 and P0302 and P0302 and P0304. The number is TSB 18-024-04. This may explain many of the 300 series of misfires and idle fluctuations that we get, or at least give us another item to have our members check to fix their problem.
Jerry
Old 03 Mar 2012, 07:46 pm
My husband regapped my pugs @ .o40 & my car wouldnt even stay started..so he regapped @ .o50 now codes,poo32,& poo38 came up.
Odometer reads all 8's waynemann General PT Cruiser Discussions 7 26 Jan 2012 08:16 am
04 GT missing and jerking, Po300 robbie109 General Turbo Discussions 13 19 Jun 2011 07:47 pm
getting a po300 veracruise Tech & Performance Forum 6 09 Dec 2010 04:07 pm
Compass always reads W/nw/sw// but never E/ne/se... matthewmilbut General PT Cruiser Discussions 9 07 Aug 2010 10:23 am
ERROR CODE PO335 & PO300 - HELP! PTZIGGY Tech & Performance Forum 7 09 Dec 2009 05:53 pm
