Oil too clean!
Old 05 Mar 2012, 07:34 pm
mdfrodolives's Avatar
Default Oil too clean!
Good afternoon, Cruisers! I have an odd question: has anyone used Valvoline Fully Snythetic oil ... and found that the oil seems to stay nice and clean--even after 1000 miles?
I'm not used to fully synthetics, so maybe this is a normal occurrance. But when I put an oil (type) product into my car's engine--and it has detergent properties, like all modern oils--I expect to see a little brownish color in the oil after a thousand or so miles. This Valvoline synthetic, seems like I just put it in--even after the miles have rolled on.
Is this normal?
Ordinarily, I use straight Castrol 5w30w (Dino), or Castrol Synthetic/Blend (a half and half sort of mixture, I suppose), and after a few hundred miles I start to see the oil get darker; so this is why I'm wondering.
Tim
Old 05 Mar 2012, 07:39 pm
Default Re: Oil too clean!
Hm? I forgot to mention that I had a new oil pan installed, just after putting in the oil. The mechanic who put the new pan on said he saved my new oil in a clean container and put it back in. So, I wonder if having a brand new oil pan (with no sludge whatsoever, obviously) has something to do with my new oil looking too new for too long.
Tim
Old 05 Mar 2012, 07:47 pm
Tim
Sounds like you answered your own question.
Old 05 Mar 2012, 09:22 pm
UptownSport's Avatar
My oil seems to stay clean for several thousand-
What dirty oil?
Get a diesel!
Old 06 Mar 2012, 10:38 am
cruserdad1976's Avatar
i change my oil every month and its not actually black it is way darker than new oil --but think the first few times you xchanged your oil in a new car its still almost clear when it comes out
Old 06 Mar 2012, 01:14 pm
I change every 5000. It always looks as clean as the day I put it in.
Jerry
Old 29 May 2012, 11:17 pm
Tim
Well, im also using the safe stuff as what called volvoline and had a new oil pan. nothing happens so i guess it's not that oil pan. Could be a leak on the tank itself...
Old 30 May 2012, 06:21 am
genaro,
What the heck are you talking about. You took a older thread that was talking clean oil and started talking about some sort of leak you had that changing the oil pan didn't stop. That was a lot of expense for something (oil pan) you didn't know was causing the leak. Should have done some more testing/searching before replacing a large part like that.
PT:Clean once again Bluecruiser The Detail Shop 6 30 Jul 2010 12:58 am
what is this and how to clean it??? morrises The Detail Shop 8 26 Jun 2008 09:09 pm
How Often do you Clean your K&N CHROMEDCRUISER General PT Cruiser Discussions 5 10 Jun 2004 05:59 pm
GT doesn't last clean LoboMXGT The Detail Shop 12 30 Dec 2003 10:58 pm
what do we clean this with?? bobs turbo pt General PT Cruiser Discussions 24 06 Nov 2003 11:15 am
