my pt has error codes p0335, p0339,p0116...help please
Old 06 Mar 2012, 09:32 pm
jrbsr05pt's Avatar
Default my pt has error codes p0335, p0339,p0116...help please
I have a 2005 pt 5 speed. The other night I went to pull away from the stop sign and right when I went to shift to second around 3000 rpm it felt like my car cut out so I drifted to the side of the road and tried to start it all it did was crank then finally got it started with a flashing check engine light. Took it home checked the codes and got p0016 and p0335. I looked up the codes and there to do with the crankshaft sensor. Well I haven't put the new one in yet cuz when I went to show my step dad it was perfectly fine and the codes were gone..it did it again today but only this time the code p0339 showed up while the others didnt so I disconnected the negative cable and sat for a few then hooked it back up and drove like normal home. Question I have is. Is it the crankshaft sensor or the camshaft sensor or something else. Iv been reading on here about other people having these problems but haven't found a sure answer.
Old 06 Mar 2012, 10:55 pm
Default Re: my pt has error codes p0335, p0339,p0116...help please
Change the sensor. The water temp sensor code as well concerns me as a possible wiring issue. But probably not.
Old 06 Mar 2012, 11:45 pm
jrbsr05pt's Avatar
Default Re: my pt has error codes p0335, p0339,p0016...help please
I'm sorry that was a mistype in the title I ment 0016. And Im not sure which sensor to change since I got 2 different ones about the crankshaft and one about the camshaft and crankshaft misalligned. But all I have to do is disconnect the negative cable or let it sit for a bit. How does a sensor do that?
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error Code P0335 firemedic1560 Turbo Performance 14 15 Jan 2012 12:42 pm
Error Codes bucksfan1976 General Turbo Discussions 0 22 Feb 2011 01:03 pm
Help with PT codes p0016 & p0339 Tiltmfc Tech & Performance Forum 0 13 Jul 2008 09:12 am
