AC High pressure switch change question
Old 06 Mar 2012, 10:29 pm
Default AC High pressure switch change question
Is changing the high pressure cycling switch same as changing low pressure switch? Read one thread that you will lose coolant-is it the same amount that you lose when changing low pressure switch? Is it just a puff or a continous loss once switch is removed?
I have changed low pressure switch, coolant level on low side ok, hear compressor cycle and fan appears to run-have not checked fuse in PDC yet. Still blows hot air-any other item to check (will bring in to check high side/complete diagnostic). Great site, has helped me through a few trying moments with my PT-son now has it and still rolling as it nears 150K.
Old 08 Mar 2012, 05:43 pm
Default Re: AC High pressure switch change question
Brought to Midas-no clue what is wrong was answer, brought to dealership and cooling fan needs replacement was their answer. Cold air before summer
Oil Pressure Switch CruisinDad Tech & Performance Forum 4 28 Dec 2012 05:40 pm
AC pump high pressure switch joereott21 Tech & Performance Forum 3 07 Oct 2011 08:19 am
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
oil pressure switch shaggypt Tech & Performance Forum 2 06 Jun 2010 07:43 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
