2001 LE Cruiser dies while driving
Old 08 Mar 2012, 01:51 pm
Default 2001 LE Cruiser dies while driving
My car has died a few times while driving down the road. It is not running rough or anything, the engine just cuts out completely. After letting it sit for a few minutes, it will start back up. I checked the error codes by turning the ignition 3 times and got code P 0320. Any input would be greatly appreciated.
Old 08 Mar 2012, 02:12 pm
fabreezai's Avatar
Default Re: 2001 LE Cruiser dies while driving
Welcome to the forums!
Try this: Error Codes
The forum search is your friend!
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 08 Mar 2012, 02:28 pm
Thanks! After searching around a bit on this forum, I've found a couple of threads that may help me. I suppose I should have done that first
Old 14 Mar 2012, 03:10 pm
Came back to update this thread. It ended up being the crank sensor.
Old 14 Mar 2012, 06:06 pm
Glad you found a fix for your PT. Thank's for the follow up. Welcome from West Virginia!
Old 10 Apr 2012, 10:48 pm
if it happens again, replace the camshaft sensor magnet. right under the sensor. you will have to get it from the dealer. $20.00. autoparts stores may not carry it and dont even have it in their schematics
2001 Died while driving compguy Tech & Performance Forum 3 07 Aug 2013 11:43 am
2003 PT Cruiser died while driving tlm Tech & Performance Forum 6 24 Sep 2011 01:47 pm
pt cruiser dies right after starting liljjjunior Tech & Performance Forum 2 23 Sep 2011 03:40 pm
2001 PT dies and won't start gto65racer Tech & Performance Forum 4 12 Feb 2011 12:36 pm
