Fuel Pump Help Replacement
Old 10 Mar 2012, 08:02 pm
Koch's Avatar
Default Fuel Pump Help Replacement
any tutorials here for a fuel pump? looked cant find one
PO344 O' how I hate you!
-2004 Chrysler PT Cruiser Limited- Inferno Red
Old 10 Mar 2012, 08:11 pm
Default Re: Fuel Pump Help Replacement
I don't see one here. The instructions in the Service Manual aren't too bad, but the owner of PTCrew.com, SnittyKitty, has posted one heck of a great Fuel Pump Replacement Tutorial over at PTCrew.com.
Go check it out, photos and all!!! Now I believe the fuel filter is part of the pump assembly, but I could be wrong....
Old 10 Mar 2012, 08:19 pm
Okay, I take that back, while the process that I listed from PTCrew is what you will need, the filter is non-serviceable. Per the '04 OEM Service Manual:
So, if you are sure you have a clogged/bad filter, you have to replace the whole pump assembly!
Old 10 Mar 2012, 08:22 pm
Probably could clean it out when you get to it.
It has a sock in the bottom, remove the bottom and back flush and blow out with compressed air.
Old 10 Mar 2012, 08:34 pm
Oops, I just noticed I read this wrong, Koch's original post was about fuel pump, not fuel filter, so the tutorial over at PTC is right on. Course her's is an older model PT, so not sure what model is Koch's. Pretty much they are all the same, I think....
Old 10 Mar 2012, 11:21 pm
Koch's Avatar
Thanks..
i have an 04 it Doesn't have the release valve on the end of the fuel rail though
Old 11 Mar 2012, 09:21 am
Thanks..
what do you need that for to replace the fuel pump? to release the fuel pressure?
IF YOU'RE DOING THIS ALONE, MAKE SURE YOU GET THE TANK AS EMPTY AS POSSIBLE. it's hard to manuver it the tank with fuel in it.
i did replace mine but dont recall the procedure. i was thinking..<~scary eh?
pull the gas cap. pull the fuel pump fuse. start car. run out of gas, crank it a few times until it wont start. remove -neg battery cable. drop tank. when dropping the tank, be carefull not to press on the center where the round depression is. this is where the float sits and you run the risk of bending/breaking it if you push to hard in this spot. carefully unhook electrical and fuel line connections
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 11 Mar 2012, 11:00 am
Koch's Avatar
the car wont start as it is so I'm assuming their isn't any fuel in the lines but you can never be to careful. going to start working on it in a little bit once its warmed up out side todays high 66! yes! lol but thanks for all the help just trying to find out how big of a job it was to take the tank out, i had a Chrysler Concorde and it was horrible to take the tank out of it lol but this seems like it isn't going to be bad
Old 12 Mar 2012, 12:43 am
Send a message via MSN to Pipeous
I did the fuel pump in a 92 exploder 4x4 myself. 6 months later the dam thing went again and I got rid of the truck. laying on my back holding that tank with my feet and hands, even my head when putting it back in. wow. lost 3 days of work doing the job and the pain I felt when done haha
Old 12 Mar 2012, 11:18 am
cruserdad1976's Avatar
we had a camaro come in and we actually had to drop the read axel to get the tank out it was a HUGE Pain
and the pump was over $500
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 08:51 pm
no fuel pump operation irishlvr Tech & Performance Forum 1 02 Jul 2011 12:12 am
fuel pump help twincruiserturbos General Turbo Discussions 10 29 Jun 2010 06:53 pm
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
Fuel pump nevinsrt Turbo Performance 4 15 Aug 2008 10:03 am
