Changed Motor Mounts Engine Shakes
Old 14 Mar 2012, 09:34 am
Default Changed Motor Mounts Engine Shakes
I have a 2006 PT base model, automatic.
I just had 2 of my motor mounts changed, the upper and lower torque struts on the passenger side.
Didn't cost a lot $67 for the lower mount and $62 for the upper one plus $60 for my mechanic to install.
However my engine now shakes quite a bit at idle in P R N and D, it shakes the least in neutral.
From what I have read here on the forum this is normal.
What kind of motor mounts do I need to put in so the engine does not shake?
Is there anything I can do to stop the shaking with the new mounts I have already?
Also when the upper mount was installed there was no way to adjust it, is that normal for a 2006 PT?
Thanks for your help
Old 14 Mar 2012, 09:55 am
ROCKETMAN8060's Avatar
Default Re: Changed Motor Mounts Engine Shakes
The upper motor mount needs to be adjusted if not then you will have the problem your having. Easy fix!
ROCKETMAN8060
Old 14 Mar 2012, 10:32 am
How do I adjust it?
There does not seem to be a way to move it.
All of the holes line up exactly including the bracket on the shock tower.
This is a 2006 PT your are talking about?
Old 14 Mar 2012, 10:37 am
Originally Posted by bob2006 View Post
How do I adjust it?
Talk to my friend XtrmDC2 he will be able to tell ya what to do, don't worry is a easy fix my friend!!!
ROCKETMAN8060
Old 14 Mar 2012, 10:43 am
Where do I find XtrmDC2?
Old 14 Mar 2012, 10:56 am
He is one of the guys here! You can find him in my profile in the friend list! Send him a PM
ROCKETMAN8060
Old 14 Mar 2012, 11:01 am
Will do thank you
Old 14 Mar 2012, 11:10 am
Ok I PM'd XtrmDC2 although I don't see the sent message in my sent message folder.....
I hope he got it.
Old 14 Mar 2012, 11:30 am
I hope he got it.
I pm him for you!
ROCKETMAN8060
Old 14 Mar 2012, 12:54 pm
I don't recall anyone ever saying that shakeing is NORMAL when you install new mounts, Because its not. Never has been. Never will be.
In all likelyhood the type of mount you have is correct unless you bought solid mounts. Unless you requested them specifically they are not would be considered a replacement for stock mounts.
You can stop the shaking by adjusting the new mounts that you currently have installed.
Yes, all stock and stock replacement mounts are configured to be adjustable. That's what the elongated slot (instead of a normal round hole) is for at the small end of the upper mount is for. It is used to adjust the upper mount to a specific length.
Please click the link below to see more details.
Broken Engin Mount
Jerry
Motor mounts going bad wasmussen General PT Cruiser Discussions 31 07 May 2015 07:23 pm
Better Motor Mounts scatgo Tech & Performance Forum 2 28 Dec 2011 02:48 pm
How to install the center motor mounts, or "Right engine mount" Leroy PT Cruiser Videos 0 21 Aug 2011 08:21 pm
PT MOTOR MOUNTS HELP !! BARRYPT General PT Cruiser Discussions 2 18 Jan 2008 12:44 am
motor mounts knowyourturbo Classifieds: For Sale/Trade 1 23 Mar 2006 07:36 pm
