freggin camshaft sensonr AGAIN?????
Old 27 Mar 2012, 10:03 pm
Angry freggin camshaft sensonr AGAIN?????
so its been 2 weeks.................2 WEEKS and 321 miles since i put in the new camshaft sensor. tonight as i went to accelerate onto the highway BAM!!!!!!!!!! car went into "limp mode" and engine light came on........all this as i was trying to take my son to the emergency room, mind you.
go there, checked the key code thing and it was
"P0344" Camshaft Position Sensor Circuit Intermittent
what the heck???? any ideas?? i torqued it to what i was supposed to....what did i do wrong? or is there another issue? is there a chance the part was a faulty part before i out it in?
Old 27 Mar 2012, 10:06 pm
Dill's Avatar
Default Re: freggin camshaft sensonr AGAIN?????
Did you use a mopar part from online or a dealership or did you buy one from an autostore.
Mopar electrical parts are the only ones that work for a long amount of time typically...
Rule of thumb, only buy mopar electrical parts.
If you did then id suggest taking it back and complaining
Old 27 Mar 2012, 10:19 pm
fabreezai's Avatar
2x what Dill said, Mopar sensors only!.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 27 Mar 2012, 10:55 pm
got it from chrysler directly at the parts counter. hopefully they will gimme another and take this one back??? could it be the wiring maybe doing this? or the connection?
Old 28 Mar 2012, 02:43 am
I had the wiring harness problem on mine. It goes from the sensor all the way around back of the engine and held up by little plastic clips. One or two of those clips let go and let the harness drop down enough so the harness actually touched the spinning half shaft and wore thrrough till the wires burnt.
I was in the middle of South Carolina so had it towed to a dealer and they pulled the same code as you. They said $200 to fix and I was too far from home to say no and while the mechanic was about to change the sensor (with harness) he found the burnt wires. Put them back together, shrunk wrapped the harness, reattached it to the engine and only charged 2 hours labor. Been that way for about 5 years without another a problem.
Old 28 Mar 2012, 06:56 pm
Bryan, please check my responce to the "Camshaft sensor again" post that was put up by ABrown around 6:13 P. M. today. It explains what I think may be your problem. Hope it helps.
Jerry
Old 28 Mar 2012, 08:29 pm
thanks jerry!! ill look into that magnet............im assuming its just called a camshaft sensor magnet? ill go tomorrow and get it
Old 28 Mar 2012, 08:42 pm
No problem. I hope that's it. It would be my next logical step. I put the part number and approximate price in the other thread and yes, that's what it is called, a "camshaft position sensor magnet".
Jerry
Old 28 Mar 2012, 08:56 pm
im just wondering.............if its a cheap part........add it to the sensor baggie itself....and add the price on. dumb mopar dumb.............
Old 29 Mar 2012, 02:54 pm
I'm just guessing, but It's probably because 99 percent of the time just replacng the sensor with a new OEM sensor will cure the problem. The magnet would only be needed if the sensor alone doesn't fix it. It's really inconvenient when the magnet is needed. Maybe now that someone has mentioned the next possability, owners will choose to do both at the same time. It's literally a crap shoot, but the odds are with the sensor alone first.
Jerry
Replacing Camshaft ChadTottingham Tech & Performance Forum 12 12 Nov 2014 09:31 pm
Camshaft sensor (again!) ABrown Tech & Performance Forum 21 29 Mar 2012 03:31 pm
Need to get bolt out of camshaft. Jooky Tech & Performance Forum 0 29 Mar 2010 08:06 pm
2 different Camshaft sensors??? 66CUDA Tech & Performance Forum 1 16 Jun 2009 10:35 pm
Camshaft Sensor ABrown General PT Cruiser Discussions 2 18 Jun 2008 07:36 am
