Non running 2.4 Ltd
  • 1 Post By UptownSport
Old 02 Apr 2012, 02:10 pm
Send a message via ICQ to Andymacc
Default Non running 2.4 Ltd
Hi this is my first post Wondering if anyone can help ???
Went over a large concrete block which damaged the sump which lost its oil The car did not go much further than 200 yards the Pulled over and the story begins!!
Got recovered and poppy went to the garage to be fixed , Firstly a brand new sump had a oil filter as well as seemed stupid not to . The mechanic couldn't make it fire so checked the spark and fitted a new coil still nothing , Had the ecu re set and still nothing checked the compression it is between 75-90 put oil down the bore and it only raised about 5 lb so nothing to write home about .
I have fitted a new crank sensor today which despite reading various threads is at the front of the engine but with a vanity mirror with a led light on located it below the starter it was a nightmare to fit having hands like shovels however its done but success I thought as now its firing in a manner the rev counter is going upto .5 but only on the key I am getting the ecu re set again but any ideas or tips would be much appreciated or will this sort out my problem ??
Old 03 Apr 2012, 12:43 am
UptownSport's Avatar
Default Re: Non running 2.4 Ltd
Originally Posted by Andymacc View Post
damaged the sump which lost its oil The car did not go much further than 200 yards ...
between 75-90 put oil down the bore and it only raised about 5 lb so nothing to write home about ...
Sounds like running without oil damaged something- This wouldn't be a surprise to anyone.
wild guess would be seized camshaft
Andymacc likes this.
Old 03 Apr 2012, 04:18 am
Hi before trying to start had covers off and poured oil over cams to stop any damage is there any way of working out if they are turning without stripping down ?
Thanks for the suggestion I will try anything at the moment
Old 03 Apr 2012, 07:48 am
Dill's Avatar
Check out this thread
Got a new pt today! Lets figure out whats wrong!
Old 03 Apr 2012, 12:19 pm
Andy, crank it over with those covers you removed off.
It's still running zip Tech & Performance Forum 4 08 Oct 2012 11:22 am
07 pt fan keeps running mrfish10 General PT Cruiser Discussions 0 03 Mar 2012 09:42 pm
not running too well!!!! ptcruiser1988 Tech & Performance Forum 10 05 Mar 2011 08:53 pm
Car Not Running - Help plang1975 Tech & Performance Forum 8 28 Oct 2008 12:15 pm
XM up and running CHROMEDCRUISER Sound and Security Forum 4 07 Jan 2005 07:22 pm
