Hello.
I drive a 2006 base Cruiser with just over 50k miles. I just paid it off and it has ran great until now. The check engine light came on soon afterwards and I had it checked at AutoZone. The check engine light was for a cylinder 2 misfire and unanimous advice was to change the plugs and wires. While I waited for them to arrive the car started idling very low/rough and kept trying to quit. It used to idle around 1100 but now idles at almost 500. Also the check engine light started to ding and blink occasionally. I changed the plugs and wires and it didn't help at all. I took it back to AutoZone to get the codes checked again and now it was reading a cylinder 2 AND 3 misfire. Seeing as cylinders 2 and 3 are on the same coil on the ignition coil I figured that was the problem. I just replaced it about 20 minutes ago and it did absolutely nothing to fix the problem. Before all this I ran a bottle of Lucas Oil fuel injector cleaner through my car because I had just gotten an oil change. The check engine light came on about a week later. After some research I had found other people having a similar problem. Initially in cylinder 2 and everything AFTER using Lucas. Before ordering the ignition coil and finding out about the second misfire I had ordered a new fuel injector for cylinder 2 thinking the Lucas product had clogged the injector or kicked something up in the system and deposited it in the injector and planned on replacing it. However even if that's the problem I need a second fuel injector. Lastly, I've noticed that upon initial start-up I hear an audible liquid sound. Like something is draining. Also after changing the coil today and standing on the drivers side of the car I got a severe whiff of gasoline and noticed the exhaust pipe was vibrating a lot, along with the engine which I presume is due to the low idle. Any thoughts or help would be greatly appreciated. Thank you. |
I'd focus on low idle-
These vehicles will attempt to 'save' the engine during overheat by dropping idle as low as possible. This will also occur if it believes it's overheating. IDK if it's diff than Neon, but there's a diff sensor for gauge than PCM- So you can't rely on the dash. Second thought turns to the AIS- It may have failed, passage plugged, or wires broken. I understand the urge to replace coil, but they're pretty good units, as you've found- The Chrysler pro Neon racer used an entirely custom transmission, valvetrain, but a stock coil! If you suspect fuel injectors- You can swap cylinder to cylinder. Good things to put in fuel tank: Gasoline Alcohol Bad things: Everything else Gasoline is some very, very wicked stuff- It'll get out stains that 'detergent' won't. Alcohol will suck up any water, and it's safe enough to drink- relatively speaking ![]()
Useful Documents Useful How-To's Have an engine code? Sometimes this link is helpful Neon Bobble Strut ^^ Click |
When I first started reading I immediately thought of a vacuum leak but then after reading more, it sounds more involved than that.
You didn't know, until now that another coil wasn't going to fix anything. Been on the forum for 10 years and a new coil never helped anyone. Its probably the best built piece of equipment on the cruiser. My suggestion is for you to get a combustion pressure/leak test and also have your coolant tested for combustion gases. I may be wrong and going for an overkill of what's wrong (hope so) but you seem to have more than a simple vacuum leak. You might want to wait to get other opinions from the forum. I'm not a mechanic. Uptown beat me to it. He's very knowledgeable on these engines. |
![]() Quote:
I see. I'm assuming I could get these things tested at most auto shops? I'm not very knowledgeable about any of these things. Also I am low on cash which is why I've been trying to fix it myself but it seems like I keep throwing money at the car and nothing is working. |
UptownSport is very knowledgeable with these cars/engines but sometimes he even says things I'm not familiar with. The PCM is your computer, not sure about the AIS.
As far as the tests I recommended, no, an auto store can't do it. You should find a mechanic you can trust to perform them and maybe get his opinion first. |
![]() Quote:
![]() Quote:
Possibly, but according to Haynes and Chilton, the two pieces on the back of the throttle body are the IAC (Idle Air Controller) and the TPS (Throttle Position Sensor) |
Sorry, was working on another car that called it a 'AIS', you're right on with the PT's being an IAC!!!!
Thread Tools | |
Display Modes | |
Cylinder 3 misfire | michalo187 | Tech & Performance Forum | 12 | 28 Jan 2017 09:30 pm |
Code cylinder 2 Misfire help | Kris35 | Tech & Performance Forum | 6 | 24 Mar 2012 09:01 pm |
Misfire In Cylinder 4 | shoe989 | Tech & Performance Forum | 13 | 23 Feb 2011 03:56 pm |
cylinder 2 misfire problem | flexse1 | Tech & Performance Forum | 1 | 07 Oct 2009 05:58 am |
Cylinder Misfire | TaylorMade | Tech & Performance Forum | 6 | 16 Jun 2005 05:01 pm |
