Engine ticking
  • 1 Post By UptownSport
Old 06 Apr 2012, 03:55 am
baz baz is offline
Default Engine ticking
Hi Guys,when my 2 ltr cruiser starts up,you can hear a light ticking,after a few seconds the engine is fine,I have changed the oil and filter,but its still the same,my question is some people do flush the engine,but others dont like doing this,what do you think,will I have major proplems,and if I do which is the best engine flush,thanks guys
Old 06 Apr 2012, 03:57 am
Kawizx9r's Avatar
Default Re: Engine ticking
Could be the injectors working, I remember a faint ticking noise when I had my PT.
My Toy
Kawi is a friggin genius!
Old 06 Apr 2012, 06:56 am
baz,
Your new here so I'll pass on some info that you would know if you read the forums before posting. For the kind of question you have, we need more information about your PT. You didn't fill in your profile but reading that you have a 2 Ltr means that your somewhere overseas and not in the U.S. We don't have that engine here, only the 2.4 Ltr engine came to the U.S., so we need to know if it's a gasoline or diesel engine. Also the mileage. If it's a high mileage engine, no matter what it is, shouldn't be flushed. Without going into detail, flushing a high mileage engine will bring more problems than what your trying to clean up. That's what I was told by expert mechanics.
If you are overseas (say England) where it's damp most of the time, your problem could be arcing of the wires. Some England owners had the problem of ticking when they first started up and it's turned out to be moisture from sitting outside. If you can, start the car in the dark and open the hood. You'll be able to see (hopefully) any arcing (sparking) that would cause a ticking sound. As the moisture dries up, the ticking goes away.
Just a thought.
Old 06 Apr 2012, 12:44 pm
UptownSport's Avatar
2.0 DOHC is the same as the 2.4 in all important aspects-
Except they carried over the hydraulic cam belt tensioner.
I'd agree with Crewzin' that there's no need to flush an engine- Motor oil does
an excellent job, and really, it matters not if there's sludge up to the cams-
If you continue to change oil on recommended intervals, it'll just sit there.
There was a 'TSB' on ticking due to cam caps- they need to be removed and
slightly chamfered. You could search for this.
Some 2.0's DOHC's also had piston knock. It doesn't hurt anything, and goes
away after less than a minute. They (IIRC) ran larger clearances than SOHC's
and 2.4's as they were only used as the high performance engine for the
Neon- and for some reason the pt ...
CREWZIN likes this.
Old 07 Apr 2012, 06:25 am
baz baz is offline
Thanks guys,yes I am in england,its a 2 ltr petrol,it is a ticking noise from the engine,its not electrical,the engine has done 80,000 miles,or 120.000 km,could I flush the engine,or is to many miles,thanks again baz
Old 07 Apr 2012, 06:38 am
baz,
Look again at mine and UptownSport's response to your question. We both talked about flushing the engine.
Old 07 Apr 2012, 07:38 am
I agree whith the other two guys, don't flush, some flushes are harsh on the bearings. This is what I do for any noise people have in there older engines, Add 1/2 bottle of "SEA FOAM" to the oil about 500 miles before your next oil change. Add the other half to the gas tank,you will be surprised what it cures.My granddaughter bought a 190k mile SunBird(Pontiac) and when it started in the AM you would swear the lifters were going to come through the covers,added 1/2 can SEA FOAM to the oil and the noise was gone within two days,changed oil/ filter and she was good to go.
Old 07 Apr 2012, 08:44 am
baz baz is offline
Thanks again guys,I will see if the sea foam will do the job,regards baz
Ticking Noise SgtGavin Tech & Performance Forum 23 28 Jul 2012 05:03 pm
loud ticking noise in my engine 96realwe Tech & Performance Forum 5 12 Feb 2011 08:41 pm
Cruiser engine makes ticking sound Markwin Tech & Performance Forum 11 06 Mar 2010 12:15 pm
Ticking Sound Blackcruiser General Turbo Discussions 3 22 Jul 2004 05:03 pm
Ticking 2003ptcrusierbrusier Tech & Performance Forum 17 26 Dec 2003 10:59 pm
