Seeeking Clutch Advice
Old 06 Apr 2012, 06:56 pm
Default Seeeking Clutch Advice
I have an'01 limited 5speed. Clutch is taking hold close to the floor,but at this time still releases well.Anyone know of a procedure to adjust this thing, while there's still some life left? Any help will be appreciated. Would adjusting it up at the pedal help? Thanx
Old 06 Apr 2012, 09:07 pm
TurboDucky's Avatar
Default Re: Seeeking Clutch Advice
Yes, there should be an adjuster on the back / upper part of the pedal.
-Gary-
2005 Dark Slate Gray Convertible - 2.4 Turbo Lite'ish - Automatic.
2001 PT Cruiser - NA - 5 Speed - Exhaust and CAI Mods - It's alive!!!
Old 07 Apr 2012, 02:19 pm
UptownSport's Avatar
The hydraulic system is most likely shot- Some PT's (If not all) had an automatic
adjuster on clutch cover, I understand there were problems with this as
an early design, but apologize I don't know details.
It may have been in a Chrysler 'TSB', you could try to search.
Some exports may have has a cable clutch, but AFAIK, all are hydraulic-
similar to the front brake hydraulic system-
Edit- The FSM does show an underdash adjustment!!!
clutch advice mattsptgt Tech & Performance Forum 5 11 Nov 2011 09:46 am
Clutch advice mikelikestobike Tech & Performance Forum 3 20 Jan 2011 03:02 am
wtb clutch Dirk_Gently Classifieds: Want To Buy 1 10 Dec 2008 09:57 am
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
