Another reversing light thread
Old 10 Apr 2012, 03:42 pm
Default Another reversing light thread
Reversing light doesn't work - I've checked the voltage to the bulb holder and it is reading 12v. I've tried 3 new bulbs, and swapped the holder from the rear fog light which works and it still won't come on. The original bulb and holder work ok in the fog lamp side as well.
Is there a correct sequence to fit the bulb - ignition on, then reverse, whistle the Welsh National Anthem and then fit the bulb?
Also, should it be a double filament type or single? The holder is for a double type, but I've also tried the single by cutting off the side lugs.
2004 2.2 CRD (GB) if that's any use
Thanks in advance
Old 10 Apr 2012, 04:13 pm
Default Re: Another reversing light thread
Thanks in advance
That is of great use because now I can't go by the U.S. model schematics. Maybe someone from Britain will come along and answer your querry.
Old 10 Apr 2012, 04:17 pm
Mine didn't work and was a bad transmission reverse switch Mine is located just on top of the transmission, right under the battery...To check it, I unplugged it and jumped the switch with a piece of wire and the lights worked, so I went to rockauto.com and ordered one..I believe was like $12
Old 10 Apr 2012, 04:21 pm
The switch works OK as there is 12v there when in reverse and 0v when in neutral
Old 10 Apr 2012, 04:31 pm
Maybe I'm wrong, but I had the impression the switch works by cutting the ground not the positive, so you may have 12v at the socket..
Old 10 Apr 2012, 04:56 pm
Checked across both terminals, not directly to earth, incase there was a dodgy earth.
Tried everything I can think of - it even makes a ding noise when I pull the bulb, so it knows the bulb is fitted
Old 10 Apr 2012, 04:57 pm
What would you suggest if it wasn't European spec?
ABS Light, Parking Brake Light, Traction Control Light kupothechocobo General PT Cruiser Discussions 9 28 Feb 2017 01:56 pm
REVERSING LIGHT - NOT WORKING Brint2006 Tech & Performance Forum 6 28 May 2016 03:43 pm
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
squeaking noise when reversing supgrrl Tech & Performance Forum 2 02 Sep 2009 10:31 am
Roaring noise from the rear when reversing?(FIXED) Ctown General PT Cruiser Discussions 3 17 Apr 2005 02:51 pm
