Why HOAT? The PT radiator coolant thread...
Like Tree26Likes
Closed Thread
  #11 (permalink)
Old 22 Apr 2012, 09:42 pm
Samson's Avatar
Default Re: Why HOAT? The PT radiator coolant thread...
FYI:
I was stationed at Comiso air station on Sicily 84-85 for the air force
  #12 (permalink)
Old 23 Apr 2012, 12:01 am
No, no no... there are many other HOAT antifreezes out there. I'm just displaying one type here. The reason behind this post is to help others stay with HOAT. You can find HOAT at many auto parts stores. Just make sure it really is HOAT, and NOT OAT.
  #13 (permalink)
Old 23 Apr 2012, 08:00 pm
rcktpwrd's Avatar
Originally Posted by Samson View Post
So that is the only HOAT made, the zerex G-05?
I see the chart says "not recommended" for Asian vehicles. So I shouldnt use it at all in my 2005 Miata?
Thank you very much for the information.
The Zerex and the MOPAR coolant are the only two HOAT coolants that I'm aware of...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
  #14 (permalink)
Old 24 Apr 2012, 10:48 am
Actually, Ford has been using a HOAT formula since 2002. There have been several others out there for about that same length of time.
1. Arctic blend G-Plus-------------------------------------Yellow
2. Daimler/Chrysler Mopar----------------------------------orange
3. Valvoline Zerex G-05------------------------------------yellow
4. Ford Motorcraft Premium Gold---------------------------yellow
5. Peak CF-EXL-------------------------------------------yellow
I've been told that, of course, Mercedes uses a HOAT formula also. Probably a few more out there.
Jerry
mnahmnah likes this.
  #15 (permalink)
Old 24 Apr 2012, 11:34 am
cruserdad1976's Avatar
actually chrysler makes a HOAT but they get like $28 a gallon for it the zerox is pretty much the same just way cheaper
Do most folks use distilled water?????? I never have just wondering
  #16 (permalink)
Old 14 May 2012, 11:28 pm
Since I bought my 2001 PT Cruiser, from a Chrysler dealer, can I assume the coolent is HOAT? Also, since the color does not always indicate HOAT, OAT or "Classic", am I reading the information correctly that adding HOAT to OAT or "Classic" is fine. ? I need to top off the fluid and really want to be sure to add the correct one. Thanks!
  #17 (permalink)
Old 15 May 2012, 10:39 am
Don't mix different flavors. If you bought it new from them then yes it has hoat. If you bought it used could be any brand.
A start from scratch might be a good way to go.
  #18 (permalink)
Old 15 May 2012, 11:51 am
UptownSport's Avatar
Yes,
I see lots of corrosion on very old cooling systems from this family.
Heads will get holes in them (thankfully between important parts), water connector neck gets pits, and radiators fill.
Would this occur if coolant were changed periodically, with distilled water?
Probably not.
  #19 (permalink)
Old 15 May 2012, 07:13 pm
Originally Posted by UptownSport View Post
Yes,
Probably not.
First there shouldn't be pitting there, second that means it needs to be shaved and polished before re-installing. Really odd place for pitting to occur.
  #20 (permalink)
Old 15 May 2012, 07:33 pm
VNT's Avatar
VNT VNT is offline
On my cars which use HOAT, I use the zerex G5 and distilled water.
If you are smart, in the PT, I just drain them every other year, add 1 gallon Zerex G5 and top with 2 1/2 qts distilled water. I have never had any issues with radiators clogging.
I did have to replace the radiator in my 03 GT because it started leaking at the crimp.
At Napa a gallon of zerex is 12$ and a gallon of distilled water from Wally World is 1$.
In my older cars I ran propolene glycol. Amsoil and Safer Lowtox
make that. The advantage with propelene is if you get any in the oil it will not wipe out the bearings but ethelene at like 3% will take out the bearings. A guy at an oil analysis lab told me that years ago.
VNT
89 Shadow ES 2.5 T2 +20's A555 sold
90 Daytona ES 2.5 T1 A523
90 Datyona Shelby VNT needs work
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
03 PT GT Black 5 sp Stg 1
05 PT GT Silver 5 Spd Conv
Closed Thread
who carries HOAT antifreeze coolant in central nj turbo1013 Tech & Performance Forum 8 26 Oct 2010 09:45 am
Radiator coolant bottle War_Eagle General PT Cruiser Discussions 1 25 Jun 2010 12:56 pm
Coolant Leak at Radiator VNT General PT Cruiser Discussions 7 15 Feb 2010 02:21 pm
Another Antifreeze-Coolant Thread Matt42 General PT Cruiser Discussions 4 01 Nov 2009 03:27 pm
PH level of HOAT Coolant yaschief Tech & Performance Forum 2 13 Aug 2008 02:01 pm
