Engine Management Light
Old 12 Apr 2012, 11:32 am
Default Engine Management Light
Hi everyone, really sorry if i have put this in the wrong place but couldnt find anything that related to my problem.
I have a 2001 X Reg Limited Edition Cruiser 2 Litre Auto, my Engine Management Light came on, and we figured out the problem was the Cam sensor, i have had this replaced, but the Engine Management Light won't go off, i have had it connected to the fault finding machines, No error codes are now found and everything is now working as it should but the Engine Management Light is still on, Does anyone know if there is another way i can get this light turned off, i have disconnected the battery for a few minutes as that was suggested but still on.
Any help would be appreciated
Thanks Mike
Old 12 Apr 2012, 11:35 am
Default Re: Engine Management Light
Mike,
If you take off the negative battery cable for about 5 minutes, that will reset the computer and clear all the codes that are stored. Also step on the brake pedal while the battery cable is disconnected. That will get rid of residual charge built up. The PT might run a little ruff for about a minute when you start it but it's just the computer re-learning your set-up.
Old 12 Apr 2012, 11:40 am
Thanks Crewzin,
Will give this a try in a little while
Thanks Mike
Old 12 Apr 2012, 04:26 pm
Originally Posted by CREWZIN View Post
Mike,
Hi CREWZIN, i tried what you said but light still there, got my mate to come over with his tester to make sure he cleared all the codes, there are no codes showing up at all!!
Thanks Mike
Old 12 Apr 2012, 05:06 pm
Mike,
I should have added that there ARE one or two fault codes that have to clear themselves. After the computer sees that the fault is no longer there after a particular amount of starts, the MIL light will be turned off. Your may be one of those faults.
Old 14 Apr 2012, 01:43 pm
Mike,
Thanks CREWZIN
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
OBD light (engine management) ronnies Tech & Performance Forum 0 03 Jun 2009 01:15 am
torque management and s2 brngrhd Stage Turbo Kits 9 22 Feb 2004 02:58 pm
