03 Overheating. What are these wires???
Old 15 Apr 2012, 05:13 pm
Default 03 Overheating. What are these wires???
Just bought an 03 PT Crusier non-turbo base model last week. 50k miles pretty clean inside. Besides all the sensor issues I fixed thanks to this site I'm still having trouble fixing my overheating problem. It only overheats when on freeway after a few exits or so it starts to climb to the point I have to blast my heat to bring it back down. I live in S. florida, it's bad enough my A/C doesn't work now I have to blast the heat lol. So far I've
-flushed the coolant taking both hoses off and running water garden hose water through it.
-replaced thermo with failsafe one.
-just replaced radiator cap.
-I pressure washed the front of the radiator
while doing the last I noticed that there was a set of wires just hanging and I cant find a location for them to plug into. there colors are purple with green stripe and black with blue stripe.. could this be the problem?
My next step would be replacing both the radiator and fan since they are pretty cheap on Ebay and I'm pretty nifty with the wrench.
I'm just dreading it being the water pump or head gasket since those are $$$$$ and out of my league of DIY.
Like I said I don't have A/C cause of the compressor being bad and I can't fix that till I find out if I have to move onto the water pump since those would be removed anyway.
WHAT is going on??? and What are these wires?? thanks
pic is below
Default Re: 03 Overheating. What are these wires???
photo7.jpg picture by Guru_TattooStudio - Photobucket
Old 15 Apr 2012, 05:28 pm
fabreezai's Avatar
guru-
Welcome to the forums! I too have an 03' one of the wires for sure is your outside air temp sensor for your overhead console. The other I believe is your front impact sensor for your airbag, Not sure, I will check my service manual to be sure and report back to you. In the meantime I'm sure someone else will chime in.
Cheers! 2003 2.4, N/A, Touring, Supercharged, 5 speed. 126k..... Blew up that engine, building another to take the boost! Built a new engine, still working out some issuess.......
Old 15 Apr 2012, 05:29 pm
That connector is for a temperature sensor for the overhead console; compass/ thermometer/ map lights. It will not have anything to do with your overheating problem.
The 2003 shop manual gives the colors as violet/ light-green stripe and black/ light-blue stripe. The connector takes a sensor similar to (but not the same as) the sensor fastened to the radiator support in your picture. That other air temp sensor sends a signal to the PCM for fuel injection modulation.
Do you have an overhead console? My 2004 did not, but did have the wiring in place (with that connector) making it possible for me to add the console.
Originally Posted by GuruCruiser View Post
Old 15 Apr 2012, 05:40 pm
nah no overhead sensor in mine. ok so i'll ignore the wires lol. hmm now wonder whats causing the overheating at high speeds? anyone have this problem and was able to fix it? again it doesn't overheat while idling or driving around town. just high speeds 60-80ish
Old 15 Apr 2012, 05:58 pm
fabreezai's Avatar
I stand corrected! Thanks Sanatana!
Old 15 Apr 2012, 06:14 pm
Guru Cruiser,
If the fan is working properly, the cruiser only needs the coolant to slowly make it's way around the engine and radiator to keep everything cool. When you get up to speed, the coolant needs to move faster to dissipate the extra heat generated by the high speed. A partially clogged radiator, a water pump that's not operating properly, a partially clogged hose and last but not least, a split in the head gasket can all cause overheating at higher speeds. You need to check things out.
Old 15 Apr 2012, 06:23 pm
Well hoses seem to be working good. do you think it's worth it to replace the fan and radiator or is that just wasting money and I should go right to replacing the water pump?
Originally Posted by CREWZIN View Post
Guru Cruiser,
X2 on that.
Old 15 Apr 2012, 06:26 pm
Need to determine what is needed. Or you could wind up replacing till you run out of money.
CREWZIN likes this.
03 Overheating. What are these wires??? GuruCruiser Tech & Performance Forum 1 10 May 2012 10:58 pm
Still Overheating? JSRocket Tech & Performance Forum 9 13 Aug 2011 01:33 pm
Help overheating!!! Kblevins Tech & Performance Forum 15 10 Aug 2011 02:45 pm
Overheating DreamcruiserII General PT Cruiser Discussions 2 02 Aug 2010 08:39 pm
Is this overheating? MEXICANPT Turbo Performance 6 31 May 2004 06:32 pm
