02 PT Cruiser Timing belt Help!!!
Old 16 Apr 2012, 12:12 pm
Default 02 PT Cruiser Timing belt Help!!!
Hi everyone
Just changed water pump,timing belt,tensioner and idler. Started it up after all together barley ran wouldnt idle so i took it all apart timing off by 1 tooth so i fixed the timing marks turned crank 2 full revolution and checked marks all good put it all back together starts and idle but barely idles wants to die give it a little gas sounds good than back to idel wants to die any ideas maybe off by another tooth? Is there possibly something i broke like vacuum line or something dont hear anything please help thank you.
Old 16 Apr 2012, 01:51 pm
UptownSport's Avatar
Default Re: 02 PT Cruiser Timing belt Help!!!
jeez- Tose marks are hard to get a good line of eyesight on.
For upper gear, use a straightedge.
Lower line up mark with exact tooth position and follow back to oil pup mark.
Start while it's all apart to check!
Old 16 Apr 2012, 02:31 pm
Ok thanks i will give it a try is it ok to start the engine with the exhaust down pipe disconnected or should i hook that up first? wish i would have thought of starting it torn apart the first 2 times
2002 PT Cruiser with broken timing belt raspberry01 Tech & Performance Forum 69 18 Jan 2013 09:06 am
05 Cruiser running rough after timing belt replacement DonSkinnerNoble Welcome New PT Cruiser Members 9 27 Jul 2012 09:19 pm
PT Cruiser Service Manuals, Oil Pan Gasket, and Timing Belt bbarton15 Classifieds: For Sale/Trade 0 05 Nov 2011 10:07 pm
02 pt cruiser,2.4 Timing belt/head gasket zmaster General PT Cruiser Discussions 14 19 Dec 2010 09:35 am
Timing Belt Change - 03 Turbo Cruiser duffner General Turbo Discussions 7 24 Jan 2008 07:38 pm
