Motor mount inserts
Old 16 Apr 2012, 09:21 pm
Talking Motor mount inserts
Does anybody know how to install the motor mount inserts on the upper and lower mounts. I want to try and do it myself along with my mopar BOV so I Dnt have to waste money paying someone for something I can do myself. Any help or suggestions will be much appreciated.
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 16 Apr 2012, 09:26 pm
Default Re: Motor mount inserts
This is how they go
Old 16 Apr 2012, 09:42 pm
Talking Re: Motor mount inserts
Cool thanks, u said 2 inserts go in each mount right?
Old 16 Apr 2012, 09:53 pm
Yes, two inserts per mount... I got you 4 extra bolts,nuts and washers, because the kit originally comes with only 4 total, to use only 2 per mount...but after a while they come out, so you'll prevent that by using 4 bolts ..
Old 16 Apr 2012, 10:09 pm
Ok cool thanks do much again, and the four bolts r pictured above right inside the Orange part?
Old 16 Apr 2012, 10:54 pm
Yes they are...Those are the same Energy Suspension inserts you got but in red color.
Old 17 Apr 2012, 07:50 am
The Prothanes are single piece each mount, and come with a giant washer to box it in from the big end.
motor mount cllwyrc Tech & Performance Forum 13 04 Feb 2012 09:02 pm
prothame motor mount inserts 1quickpt Turbo Performance 3 22 Jan 2006 11:17 pm
F/S:Motor Mount Inserts JSTANEON Classifieds: For Sale/Trade 1 11 Mar 2004 10:26 am
Engine Mount Inserts..? Rolo Tech & Performance Forum 21 28 Jan 2004 07:08 pm
Motor mount mod. PVO PT Turbo Wheels/Suspension/Handling 4 28 Jun 2003 02:30 am
