Is it possible to be 180 off when setting timing?
  • 1 Post By UptownSport
Old 18 Apr 2012, 07:51 pm
Default Is it possible to be 180 off when setting timing?
Just finished new head gasket, timing belt etc. on 02 cruiser, started it up & it acted like it was out of time. I had the marks perfectly lined up after installing belt. Motor idled rough & surged after you let off the throttle. I talked to a trusted mechanic & he said I must be 180 off. After tearing it down again, I'm uncertain how I could be 180 off when the cam sprockets say "up" & crank is at TDC. Help?
Old 18 Apr 2012, 08:52 pm
UptownSport's Avatar
Default Re: Is it possible to be 180 off when setting timing?
On the next revolution cams would simply be 'on'
Most likely, it's a tooth off.
rob342 likes this.
Torque setting for Manifold? jhn_plsn Tech & Performance Forum 15 08 Mar 2011 02:35 am
Setting The Inside she_so Interior Accessories Forum 4 22 Mar 2009 05:19 pm
What is the best comfort setting? Ctown Wheels, Tires, Suspension 2 18 Oct 2004 12:41 pm
Setting new standards turbomangt The Detail Shop 0 03 Jul 2004 08:34 am
