Turn signal problem
Old 19 Apr 2012, 08:47 pm
Question Turn signal problem
I am trying to fix the left front turn signal on a 2006 cruiser.
I beleive it may be the DL driving light circuit is bad.
* MF switch is common to dash indicator and front lamp.
* Interior indicator flashes like a bulb is out.
* Left rear lamp flashes (fast)
* I have removed the connector on the bottom of the under
hood fuse/circuit board asssembly and can light the lamp by applying
12V to the Grn/wht wire in the connector.
1. Is there a schematic for the circuitry in the under hood fuse/circuit box?
2. Anyone else had this problem & what fixed it?
Thanks,
Karenscruiser:
Old 19 Apr 2012, 09:33 pm
Default Re: Turn signal problem
mine would come on if i tweaked the bulb so it had a better connection. stupid bulb socket was too loose. then i broke the brass out of the bulb socket gently trying to bend it.
-try twisting the bulb. if that works, try bending the wire on the bottom of the bulb, not the brass in the socket.
Old 12 Jun 2012, 02:12 am
I've been on the same boat several weeks ago and suddenly discovered that LED compatible flasher will do the trick especially on the electric car load and turn signal light issues. There are units that are a direct replacement which works best.
2006 TURN SIGNAL PROBLEM dj78nc General PT Cruiser Discussions 26 24 May 2015 12:52 pm
Turn Signal Problem 2007 Pt Twinb2 General PT Cruiser Discussions 4 26 Sep 2012 02:46 pm
2005 turn signal problem ricksterw General PT Cruiser Discussions 7 18 Feb 2010 05:59 pm
Rear turn signal problem leroy420 General PT Cruiser Discussions 5 18 Feb 2009 09:43 pm
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
